Author Topic: Boredom = Custom seal driver  (Read 2992 times)
zippo
  • Turtle Points: 569
  • Male Posts: 1,554
  • Member since Nov '08
    • oppiz.net
« on: May 01, 2018, 11:33:23 PM »
I got bored and made a seal driver. On r-series transmissions you have to drive the seal in from the rear which can be a pain. Also the depth on this seal is critical which also makes it a pain. This should make it much easier. The driver is made so it aligns on the front  bearing/seal holder and should make pressing or driving the seal is super easy.
If you see it, its for sale.
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5143
  • Male Posts: 4,210
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: Boredom = Custom seal driver
« Reply #1 on: May 02, 2018, 04:48:04 AM »
Nice tool!!
The photos look like one of the few rubber/metal seals that is installed into a housing backwards – with the open side out.
I would not want to be “driving” that type of seal and concerned about damaging it.  :disturbed:
I use some simple thermodynamics.  I put the seal in the freezer for several hours and when I get ready to insert the seal, I heat the housing up, coat the outer part of the seal with a little silicone spray, and use a big socket that fits, pressing it by hand very carefully.  I use the same trick (freezing the caps) when installing bearing caps into U-joints......
....I just can’t get the drive shaft into my oven.  :shake:
Gnarls.  :gap:
« Last Edit: May 02, 2018, 04:56:30 AM by Gnarly4X »
zippo [OP]
  • Male Posts: 1,554
    • oppiz.net
« Reply #2 on: May 02, 2018, 07:30:31 AM »
I have never had much luck with thermal only install of rubberized seals and I also don't have a socket that fits the seal, hence why I made one. I drive or press them. This seal has a very specific depth it has to be set at too, which just adds to the complication.
The worst install I have was on diamond axles. They also are driven in backwards, and suck. you just don't have enough room from.
Last post Oct 04, 2005, 05:51:32 PM
by GoYoTaGo
Last post Sep 19, 2007, 10:36:15 PM
by Hammerhead
Last post Sep 22, 2008, 12:14:31 PM
by OFRD_GRL
Last post Sep 24, 2010, 02:04:53 PM
by santa cruz crawler
Last post Oct 29, 2012, 12:34:21 PM
by coryc85
