Author Topic: 89 style ps steering box on 86 pickup  (Read 489 times)
Djencee
  • Member since Apr '18
« on: Apr 30, 2018, 05:27:35 PM »
Ive gathered up my parts to convert my 86 4x4 22r pickup from manual steering to power steering. I was only able to get my hands on a 89-94 style box and have found some conflicting ideas about being able to interchange boxes.
The 89 style is longer than 86 by about an inch. Is it possible to change the length of the steering shaft at the slpine connection to the steering column to make the shaft shorter or is there another way?
Just wondering how I can make this work and how much extra work it would be. Thanks
H8PVMNT
  • Turtle Points: 451
  • Male Posts: 3,450
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: 89 style ps steering box on 86 pickup
« Reply #1 on: May 01, 2018, 10:47:53 AM »
No you can't shorten the box shaft but you should be able to shorten the column shaft easy enough.  Can you weld?
I was thinking back in time and I believe some of the steering shafts have a kind of tight slip in them that is flat on two sides and has some nylon kind of stuff on the shaft.  I think you might be able to collapse that slip a bit with a soft hammer.
« Last Edit: May 01, 2018, 11:02:50 AM by H8PVMNT »
I would rather wake up in the middle of nowhere than in any city on earth.
Steve McQueen
Djencee [OP]
« Reply #2 on: May 01, 2018, 02:08:10 PM »
I can weld if I need to, I would assume I just need to cut the steering shaft somewhere above the rag joint and make up for the difference there?
I also see the slip joint you are talking about. Just wanted to make sure I could make up for the difference in length before I hit it with a hammer.
« Last Edit: May 01, 2018, 02:53:03 PM by Djencee »
H8PVMNT
  • Male Posts: 3,450
« Reply #3 on: May 03, 2018, 03:12:42 PM »
Play with the slip with a mallet and a block of wood, if you don't like the look of it then cut it and sleeve it with a bit of tube or pipe.
Steve McQueen
Last post Jul 29, 2005, 06:32:08 AM
by grumpy1@netptc.net
Last post Oct 11, 2006, 02:43:32 PM
by hozzer1
Last post Jun 11, 2007, 11:11:19 PM
by Snowtoy
Last post Jan 03, 2011, 12:32:16 PM
by Fisch_Taco
Last post Mar 30, 2012, 07:40:21 PM
by 79coyotefrg
