Will you be running an isolator? If memory serves, the charge rates between wet and agm can be different and cause issues, though that is a fragmented memory from when they first came out with agm.
I run dual Odyssey battery's and have for at least 12 years. My battery's are mounted in the back on each side. I made my own cables out welding cable 0 and 1 in size. I do not run an isolator or switch and have never had a problem and I have worked the winch for long periods. I also have a 180 amp GM style powermaster alternator, the system has worked flawless all these years.Sidenote. My tow rig is an 04 Ram 2500 CTD and it came with dual battery's. One day I was checking out the system on it and it does not have an isolator or switch of any type either.
Started by JOE 88 Toyota Pickup/4Runner Tech 1979-95
Started by franky112665 General 4WD Discussion
Started by motoracer Toyota Pickup/4Runner Tech 1979-95
Started by 83yota Engine
Started by Lobo176 Toyota Pickup/4Runner Tech 1979-95
