Author Topic: 16" rims on 1st gen 4x4 pickup  (Read 404 times)
idahank
  • Member since Nov '13
« on: Mar 07, 2018, 08:10:08 PM »
I have a 1980 4X4 long wheel base truck with a 22r motor an I am thinking of putting some 16" rims and tires on it  Have any of y'all put 16" wheel on aa 1st gen truck??
Cheesemaker
  • Turtle Points: 1358
  • Male Posts: 4,446
  • Member since Sep '04
Re: 16" rims on 1st gen 4x4 pickup
« Reply #1 on: Mar 07, 2018, 08:15:24 PM »
Its only 1" larger than a 15".   :yupyup:
With 16" there will be alot more options.  But most will be 8 or 10 ply tires.  Vs. 15" most will be 6 ply.  8/10 ply tires will weigh more, due to more belt construction.
mudmaster
  • Turtle Points: 1623
  • Male Posts: 2,561
  • Member since Feb '05
« Reply #2 on: Mar 08, 2018, 05:20:18 AM »
I have 16.5s................
Time to go wheelin!
immi.jfreeman
  • Member since Aug '15
« Reply #3 on: Mar 08, 2018, 05:47:03 PM »
I ran 16" landcruiser wheels on my 82 for a while with iroks Didn't have any complaints except I didn't like the Off-road tire options. If it was a DD with some off occasional off roading I would still have them. Fit well, looked good. Had to take them off to swap to bead locks and treps.
Sent from my XT1650 using Tapatalk
Toyotadon
  • Turtle Points: 261
  • Male Posts: 236
  • Member since Dec '08
« Reply #4 on: Mar 12, 2018, 02:27:02 PM »
The only thing I've seen cause a problem is that the offset on most non-original wheels will cause rubbing with the factory steering arm.  You might have to run a spacer if you don't plan to change the steering.
immi.jfreeman
« Reply #5 on: Mar 12, 2018, 02:46:46 PM »
I agree. I run a crossover steering on my 1st gen and had to run a 1/4" spacer to keep from hitting my tierod with the landcruiser wheels. But I had zero issues with a set of procomp steel wheels I ran. The backspacing was better than the factory LC wheels. 3.75" I think
slacker
  • Turtle Points: 759
  • Member since May '07
  • Master Mould Maker
« Reply #6 on: Mar 13, 2018, 06:13:30 PM »
I have 16's on my Trekker ..  no problem
TREKKER PARTS
86  "shop truck"  lots of fiber parts .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
Last post Mar 15, 2006, 12:16:23 AM
by Yota Up
Last post Mar 23, 2009, 07:38:38 PM
by YotaChris
Last post Apr 23, 2010, 05:29:16 PM
by broke40
Last post Jun 10, 2010, 07:53:13 AM
by jimmer009
Last post Mar 25, 2012, 08:17:41 PM
by spc mike
