Author Topic: 22re issue  (Read 5439 times)
94Yota22re
  • Turtle Points: 1185
  • Male Posts: 18
  • Member since Jan '17
22re issue
« on: Feb 28, 2018, 04:08:16 PM »
Hello, the 22re in my truck is having some very odd running issues that after like 8 months of trial and error I still can't figure out. It dosen't rev past 4500 rpm when I go WOT with the truck sitting still. If I gingerly rev it, it will go to 5000 rpm. The VAFM goes crazy when alot of throttle is applied (over 1/4). At full throttle the truck boggs and backfires really bad like its running way lean. Any help is appreciated, thanks.
gnob
  • Turtle Points: 486
Re: 22re issue
« Reply #1 on: Feb 28, 2018, 04:21:45 PM »
Fuel filter or afm is jank
hold this. . .
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #2 on: Feb 28, 2018, 04:51:47 PM »
Fuel filter is new, replaced the afm with two other units and still same problem.
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,238
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: 22re issue
« Reply #3 on: Feb 28, 2018, 05:15:44 PM »
Hi 94Yota22re,
Before we start pulling rabbits out of butts, would you mind describing what exactly has been done in 8 months to try to figure out the problem?
Thank you.
Gnarls.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 22re issue
« Reply #4 on: Feb 28, 2018, 05:21:10 PM »
Bad gas (water ? )
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #5 on: Feb 28, 2018, 05:26:50 PM »
I have replaced the AFM, ecm, tps, fuel filter and injectors. The fuel filter and injectors were replaced when the topend was done an it ran great for about 3000 miles then all this started.
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #6 on: Feb 28, 2018, 05:28:59 PM »
Bad gas (water ? )
It's had several gallons of fuel ran through it since this started so there's no way
OVRAROK
  • Turtle Points: 26840
  • Male Posts: 3,508
  • Member since Dec '10
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #8 on: Feb 28, 2018, 05:53:11 PM »
I have adjusted the tps but, even if it was out of adjustment it wouldn't cause the problem i'm having right?
OVRAROK
  • Male Posts: 3,508
Re: 22re issue
« Reply #9 on: Feb 28, 2018, 06:00:40 PM »
Was 1 of AFM off a running truck.
gnob
Re: 22re issue
« Reply #10 on: Feb 28, 2018, 08:02:45 PM »
Clogged cat
hold this. . .
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: 22re issue
« Reply #11 on: Feb 28, 2018, 11:30:54 PM »
Checked the timing?
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: 22re issue
« Reply #12 on: Mar 01, 2018, 01:42:26 AM »
Full Moon
 :moon:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #13 on: Mar 01, 2018, 07:10:36 AM »
I just tested the afm and it is perfect. Timing is right on.
OVRAROK
  • Male Posts: 3,508
Re: 22re issue
« Reply #14 on: Mar 01, 2018, 08:29:23 AM »
have you checked for crack or leak in plastic intake tube that runs from TB to AFM.
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #15 on: Mar 01, 2018, 09:36:17 AM »
Yes it had a crack in each of the rubber ends but I taped them up and no difference.
OVRAROK
  • Male Posts: 3,508
Re: 22re issue
« Reply #16 on: Mar 01, 2018, 09:51:30 AM »
do you have a way of testing fuel pressure?
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #17 on: Mar 01, 2018, 10:18:45 AM »
No I don't, at least not at the rail I've heard something about drilling and tapping the back of the fuel rail for a 3/8 npt fitting. Is that the only way?
OVRAROK
  • Male Posts: 3,508
Re: 22re issue
« Reply #18 on: Mar 01, 2018, 10:55:38 AM »
you can drill and tap an extra banjo bolt thats at the cold start injector, 1/8 npt. Then thread 1/8 npt to barbed end in. hose to barbed end, to a pressure gauge. i know lc engineering sells a kit if you would rather just purchase. lc engineerings kit is permanent solution
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #19 on: Mar 01, 2018, 11:03:41 AM »
Thanks, I'll probably just buy the lce kit. I'll report my findings after.
Snowtoy
  • Male Posts: 2,583
Re: 22re issue
« Reply #20 on: Mar 01, 2018, 02:26:31 PM »
The accordion section is also prone to crack with age.
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #21 on: Mar 01, 2018, 03:33:42 PM »
I found the problem! There are several lobes wiped off the cam I would post pics but I don't think I have enough posts.
OVRAROK
  • Male Posts: 3,508
Re: 22re issue
« Reply #22 on: Mar 01, 2018, 03:43:14 PM »
Good to hear  :thumbs:
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #23 on: Mar 01, 2018, 05:28:42 PM »
Certainly, I think what caused it was a mix of too high spring pressure from the cheap chinese head I used and an improper break-in procedure.
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #24 on: Mar 01, 2018, 05:47:57 PM »
Now I can post the pics. Pretty bad eh?
Gnarly4X
  • Male Posts: 4,238
Re: 22re issue
« Reply #25 on: Mar 01, 2018, 06:14:10 PM »
During the 8 months that you experienced and attempted to diagnose the problem, did you ever remove the rocker cover and inspect the camshaft and adjust the valve lash?  :dunno:
Whose head and camshaft did you install and what camshaft break-in procedure did you use? :dunno:
Did you install a new rocker rack or use a used one?  :dunno:
How many miles on the engine before the new head and cam was installed?  :dunno:
Why do you suspect "too high spring pressure"?  :dunno:
Gnarls. :inthedark:
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #26 on: Mar 01, 2018, 06:47:38 PM »
I did take the rocker cover off and check the valve lash. It seemed to be fine. The engine never had any exessive ticking so I suppose the flat part of the lobe remained okay. I have absolutely no idea how on earth I could have missed the lobes being worn so bad :smack: the head and cam were super cheapies that I bought from Amazon. I never did any research on the quality of the parts. The rockers were original and I didn't do a proper break-in. The engine had 183,000 mi on it iirc. I read a thread on pirate that was about the chinese heads and that the valve springs were very think. I will find a factory head and confirm this later.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: 22re issue
« Reply #27 on: Mar 01, 2018, 07:51:13 PM »
Did you put the rocker arm assembly together correctly?
I've seen wiped lobes when the shafts didn't have the oiling holes in the correct orientation.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
  • Male Posts: 4,238
Re: 22re issue
« Reply #28 on: Mar 02, 2018, 02:09:19 AM »
"The only source of knowledge is experience."
~ Albert Einstein
Gnarls.
94Yota22re [OP]
  • Male Posts: 18
Re: 22re issue
« Reply #29 on: Mar 02, 2018, 02:19:26 AM »
I never took it apart. It came off in one piece, it went together in one piece. I wasn't smart enough to pull it apart and clean the oiling holes..
Last post Jan 09, 2006, 06:12:44 AM
by b_ripper8
Last post Apr 10, 2010, 06:40:02 PM
by chim
Last post Apr 03, 2010, 07:30:53 PM
by tom85
Last post Oct 07, 2015, 11:33:53 AM
by 84_yota_4wd
Last post Dec 10, 2015, 08:51:43 PM
by dgalloway21
