Author Topic: Will it work or not?  (Read 7695 times)
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
Re: Will it work or not?
« Reply #30 on: Feb 19, 2018, 07:30:25 PM »
Audio equipment lol forgot about that one. Back in the late 90's I'd have been drawn into that debate. Now I've lost touch and hearing
At least we all agree my transmission needs help & apparently so do I , so there's a start
Lucas will quiet you as well.... :boozer:
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5143
  • Male Posts: 4,210
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #31 on: Feb 20, 2018, 01:57:17 AM »
No I haven't watched the video where Lucas foams.
 Honestly the last 30 days I've watched, read  and looked into more information about lubrication products than ever before in my life. The one thing I've learned for sure is there's to many opinions on the topic to know who's correct & everyone is an expert in their own right. It seems there's also as much defense of one's personal beliefs on oils & lubrication products as there is political & religious topics
So I'll likely do what I've done with the last two topics , test things myself, study as unbiased as possible & use logic with my own reasoning to form my own beliefs. I'll undoubtedly get some things wrong and adapt my view with time & experience.
Thank you all for your opinions and information .
Very well stated!  :beerchug:
Gnarls.
Gnarly4X
  • Male Posts: 4,210
« Reply #32 on: Feb 20, 2018, 02:25:13 AM »
do you have a problem with me?   because I am getting quite fed up with your smart ass comments.   If you were not trying to piss me off you might have noticed I directly replied to a comment YOU MADE.
I have seen you come into numerous threads right behind me and word your remarks different but say the exact same thing as I have to try and contradict what I have said and I am getting fed up fast.
What?
You said… “oil that thick might actually do more harm than good”
I said.... “I don't believe you can damage the gears or bearings by running heavier gear oil unless you’re
running your truck in sub-zero temperatures."
The Amsoil viscosity is too heavy.”
I agreed with you.
Then you said…. “maybe because the thick THICK viscosity may not circulate into the bearing and cause it to over heat because it was in effect starved of oil?”
Then you said…. “What??   why is that Amsoil too heavy??    I can't wait to hear this.  ”
Then I said… “250 lbs. of gear lube is a LOT of weight!!”  :gap:
THAT IS INTENDED TO BE A FUNNY!
Then I said… “The 250w gear oil is OK, but the reason I suggested a lower viscosity is because you have noise, which you have not been able to fully identify the source.  If you go too thick, at cold ambient temperatures, the synchros and other more critical components inside the tranny will not be messing and causing intermittent grinding.
AGAIN, AGREEING WITH YOUR COMMENTS!
Why would that piss you off??  :dunno:
Gnarls. :inthedark:
gnob
  • Turtle Points: 486
« Reply #33 on: Feb 20, 2018, 06:01:52 AM »
The thicker oil doesn't wash off the sycros as well, especially when cold.  It can make shifting a PITA.  im running a delo semi syn in mine and when its shitty cold out, the first half dozen shifts aren't smooth.  ;)
hold this. . .
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #34 on: Feb 20, 2018, 07:33:34 PM »
he is in Oklahoma
gnob
« Reply #35 on: Feb 21, 2018, 05:47:26 AM »
hold this. . .
CrawlerBrennan
  • Turtle Points: 9207
  • Male Posts: 428
  • Member since Jun '07
« Reply #36 on: Feb 22, 2018, 05:02:08 PM »
so... Oil will not fix anything but running a very heavy oil can keep oil from getting to all sections and nooks and tight spots. With that said we can get you taken care of with a rebuild kit (if you change your mind and want to take that on) or with a rebuilt unit when you are ready for that. This was an interesting topic
Lets go camping
Gnarly4X
  • Male Posts: 4,210
« Reply #37 on: Feb 22, 2018, 06:13:24 PM »
... Yep... reads just like a salesman...  :beerchug:
Gnarls.  :gap:
blackdiamond
  • Male Posts: 5,052
« Reply #38 on: Feb 22, 2018, 07:42:12 PM »
Gnarls.  :gap:
But will he answer the phone if we call?   :D Bazinga!
  • Turtle Points: 1051
  • Male Posts: 9,755
  • Member since Oct '04
« Reply #39 on: Feb 22, 2018, 07:51:03 PM »
He has whenever I have called :dunno:
blackdiamond
  • Male Posts: 5,052
« Reply #40 on: Feb 22, 2018, 07:55:27 PM »
There's just been another complaint on the forum about them not answering.  It was an attempt a humor...
  • Male Posts: 9,755
« Reply #41 on: Feb 22, 2018, 08:02:20 PM »
Ahhh, touché.  I never laugh, just ask anybody who knows me.  I have barely ever called them but have always got through.
CrawlerBrennan
  • Male Posts: 428
« Reply #42 on: Mar 01, 2018, 09:09:21 AM »
Ahh man I hate to hear/see stuff like this we really do answer every call that we can as fast as we can.
Lets go camping
blackdiamond
  • Male Posts: 5,052
« Reply #43 on: Mar 01, 2018, 12:03:28 PM »
You guys do a great job and I have always been happy with your customer service.  I figure if you're busy that mean longevity for the business and more opportunity for product development.
It was intended as an inside joke given a very recent complaint that follows the somewhat normal pattern of someone signing up for the forum with their only intent to be a complaint resulting in a bit of a flaming.  We got your back!
Gnarly4X
  • Male Posts: 4,210
« Reply #44 on: Mar 02, 2018, 02:01:22 AM »
I also have had great customer service and products from Marlin. I’ve said many times, if it weren’t for Marlin I would not have enjoyed wheeling my 85 shortbed for 10 years.
However….. when it comes a profit oriented sales-driven company, there are only two ways to increase profit – increase revenue (sales) or reduce costs (overhead).
There are 3 things that are absolutely key to successful business development….
Customer Service
Customer Service
and Customer Service
Gnarls.
Last post Aug 15, 2011, 06:44:25 AM
by 79rockcrawler
Last post Jan 03, 2006, 02:38:50 PM
by Hyena
Last post Jan 17, 2006, 08:32:26 PM
by Skinny_Pedal
Last post May 25, 2006, 07:23:31 PM
by 79coyotefrg
Last post Aug 09, 2006, 06:28:16 AM
by bluetoy84
