Author Topic: Rexy Re-Do: SUPER SLEEPER 1ST GEN!  (Read 21707 times)
:)bestgen4runner
  • Online The 1.5K Club
  • Turtle Points: 2134
  • Male Posts: 1,615
  • Member since Mar '16
Re: Rexy Re-Do: SUPER SLEEPER 1ST GEN!
« Reply #390 on: Jan 05, 2019, 01:15:22 PM »
And the engine goes back in.  Just have to put in the radiator and hook up the doodads and we can go back to work!
I've seen some back yard :pokinit: before, but that is some serious gagster :pokinit:. I know You got to have some chain around there someplace.
I am 1/5th of Perfect Fit
Gnarly4X
  • Turtle Points: 3103
  • Male Posts: 2,701
  • Member since Jun '16
  • Marlin and I slid "The Sluice" Martinez Canyon
    • Buy me some coffee
« Reply #391 on: Jan 05, 2019, 01:52:05 PM »
Two of the flywheels, the bad ones, were 22 lbs and the good one was 24 lbs. The newer style one I had been using was 24 lbs too so I was glad not to change since I've been so happy with the trucks performance.  The 1,600 lb pressure plate is 3 lbs lighter than the old one which is interesting.
My factory stock flywheel, after it was balanced, weighed 24.5 lbs.  I did not have a "step".  For a healthy clutch disc and pressure plate, if you can smoke a clutch disc due to insufficient clamping pressure from a Toyota factory pressure plate behind the stock engine it came mounted on, you may need some clutch pedal-gas pedal technique tutoring.  :gap:
Gnarls.  :blah:
1986 XtraCab SR5 22RE 5speed W56B, ~15,000 MI after break-in, DIM (Did It Myself) rebuilt engine - .020" over, engnbldr RV head, OS valves, 261C cam, DT Header. https://imgur.com/oACTHTR
Gnarly4X
  • Male Posts: 2,701
« Reply #392 on: Jan 05, 2019, 01:55:43 PM »
Nope... that is what MacGyver would use!!!!  :thumbs: :gap:  :yesnod:
Gnarls.  :beerchug:
H8PVMNT [OP]
  • Turtle Points: 458
  • Male Posts: 3,440
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #393 on: Jan 05, 2019, 05:10:55 PM »
Well, if I remember correctly I put those into service last winter when all my stuff was buried under about a foot of snow.  I had the engine hoist but no chain handy.  I had tore down a bunch of 20Rs and that was all in the shed so when I was trying to figure out what the heck to use at 4:00AM and zero degrees there were the old timing chains in the bottom of a greasy box.
As it turns out they keep things level, centered and kind of more rigid than regular linked chain.  They work so good that I have just kept on using them.     :sly:
I would rather wake up in the middle of nowhere than in any city on earth.
Steve McQueen
H8PVMNT [OP]
  • Male Posts: 3,440
« Reply #394 on: Jan 05, 2019, 05:20:38 PM »
I have always been happy with stock clutches as long as I have good gearing for my tire size, but I bought this one gently used from 05sport4x4 on here for cheaper than I could have got a stock style replacement. Apparently he used it on a 22re just a few runs before an engine swap. The disk, Japan throwout bearing and pressure plate all looked nearly new so I was happy.
Pedal pressure seems no more than stock and it hooks up smooth and positive.  Better than my janky oil soaked old one for sure :).
Steve McQueen
Last post Jun 29, 2004, 12:04:08 AM
by 84runner
Last post Nov 03, 2004, 09:27:16 PM
by kyle_22r
Last post Feb 25, 2005, 10:23:27 PM
by Mike D
Last post Nov 06, 2005, 11:12:40 PM
by wa4x4
Last post Dec 18, 2006, 08:00:19 AM
by *** YELLER ***
