Author Topic: Need help with late model r150f  (Read 1993 times)
foxtrot
  • Member since Nov '06
« on: Nov 16, 2017, 07:28:45 AM »
Vehicle : 2001 4x4 Xtra cab 3.4 5 spd r150f
I took a 600 mile trip and ran the transmission with extremely low oil. In 5th I started hearing a humming and put it in nuetral then lost 1st 2nd 3rd 5th and R. I dropped the transmission and pulled the case off and the 4th gear on the input shaft had all the teeth sheared off and some of the teeth wear welded into the corresponding gear on the countershaft.
So my issue is finding a replacement r150f had been tough.  I am left with trying to find a r150 from a 4x2 and swapping the end case and output shaft.  (Also taking a gamble on condition of the rest of the tranny). Or doing a rebuild. Of course I've got to find a replacement for those two gears and hub  also assuming the shafts are in rebuildable shape. Advice? Opinions?
gnob
  • Turtle Points: 486
Re: Need help with late model r150f
« Reply #1 on: Nov 16, 2017, 11:56:02 AM »
Cant you just get an early 150 and swap inout/ootput shafts?
hold this. . .
foxtrot [OP]
« Reply #2 on: Nov 16, 2017, 01:40:08 PM »
Negative early input shaft it shorter I believe. I might be able to swap the 4th gear counter gear and hub tho. not sure if they are the same diameter
Sent from my SM-G955U using Tapatalk
foxtrot [OP]
« Reply #3 on: Nov 20, 2017, 01:27:54 PM »
I ended up just buying a new transmission. I'm tired of fighting the paisonos at the auction for a donor truck. Man the Mexican importers have ruined the secondary market on these vehicles.
T-Revv
  • Turtle Points: 722
  • Male Posts: 279
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
« Reply #4 on: Jan 31, 2018, 01:13:05 PM »
I think what gnob was saying was that an early R150 has the same gear set and internals, with a shorter input.  So if you use your input in an older R150, and also your tailhousing so it bolts to your tcase, it would work.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
foxtrot [OP]
« Reply #5 on: Feb 04, 2018, 10:01:18 PM »
Ahh my input was fragged...unless I could have swapped that gear...
Last post Jun 22, 2005, 03:38:34 PM
by Jeremy
Last post May 31, 2007, 09:04:55 PM
by 79coyotefrg
Last post Oct 25, 2014, 07:58:35 PM
by OVRAROK
Last post Jun 21, 2018, 05:40:27 AM
by pcyc
Last post Dec 08, 2018, 11:18:30 AM
by OVRAROK
