Author Topic: A few pics from my R150f frankenbox build  (Read 5436 times)
Andrew_ln66
  • Member since Oct '17
« on: Nov 08, 2017, 05:59:39 AM »
It was requested in another thread that I post up some pics of my gearbox rebuild so here you go!!
It's going behind a built 7m-ge 6 cylinder in an LN65 truck.
New Toyota genuine bearings, seals and syncros throughout. MC thrust washer, bearing retainer, shift fork and shifter bushes/seats. Longer input shaf. Taller 5th gear from the Dyna truck gearbox. 7mgte bellhousing, 7mge heavy duty clutch, concentric slave
A rather expensive pile of parts:
A rather daunting pile of parts:
Starting to come together with the help of a BFH
Into the intermediate plate they go
Shiny new 5th gear
Shifter gizmos installed
All buttoned up with cases
Last thing to do was setup the concentric slave cylinder spacers and lines etc
Quick peek up its skirt, new heavy duty clutch was balanced with the flywheel
And just a quick vid of all the gears turning and f*cking with my eyes!!
[video=youtube;Zm5qPYzXG4w]https://www.youtube.com/watch?v=Zm5qPYzXG4w[/video]
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
Re: A few pics from my R150f frankenbox build
« Reply #1 on: Nov 08, 2017, 10:31:13 AM »
your link did not quite work
Andrew_ln66 [OP]
« Reply #2 on: Nov 08, 2017, 02:27:15 PM »
Thank you!
Andrew_ln66 [OP]
« Reply #3 on: Nov 09, 2017, 10:47:13 PM »
It's just a generic aftermarket CSC. The brand is Howe, can't remember the part number sorry. Lots of mobs make them (Tilton etc), just have to pick one that suits the stock 35mm OD input shaft sleeve
I went this route as the OS giken twin plate clutch I was going to run came with a rubbish push/pull converter that I wanted to get away from (the 7m->R bellhousing uses a pull clutch)
I chose that particular one because it's the smallest compressed height of any I found. I was originally going to space the flywheel back 30mm off the crank to deal with the shorter input shaft of the r150 so I didn't have a lot of room left to play with. Now I've got the longer input shaft it's not an issue so I could have probably run almost any CSC in the end.
Otherwise its main advantage is simplicity. It's the bearing, carrier, fork, pivot and slave all in one.
Master wise I'm using a 3/4" land cruiser unit, most CSCS like a bit more than 5/8"
Darthyota
  • Member since Mar '18
« Reply #4 on: Mar 21, 2018, 11:50:36 AM »
Whats you're 5th gear ratio?
Last post Nov 08, 2004, 10:32:13 PM
by NUb
Last post Jan 07, 2009, 11:42:49 PM
by 86 4runner
Last post Mar 22, 2006, 03:51:26 PM
by lilbuddy
Last post Apr 04, 2010, 10:48:31 PM
by Dingman.
Last post Jul 20, 2021, 03:01:14 AM
by sostoecked
