Author Topic: Issues installing gear ring on yukon air locker  (Read 1522 times)
olyredrunn
  • Member since May '17
« on: Nov 04, 2017, 05:36:49 PM »
Everything has gone pretty smoothly until I tried installing the new ring on the locker. It just won't go on. I have 2 kits and have tried combinations of rings and lockers thinking maybe there was an issue with one of them and have the same problem every way. It has been oiled, warmed up the ring hoping for it to expand a little, hit it with a mallet...no luck. All of the install videos I've watched the ring basically fell right on. Maybe a couple taps on it if it stuck a bit.
Any tips?
gnob
  • Turtle Points: 486
Put locker in freezer. heat gear. Itll geaux.  ;)
hold this. . .
knapp870
  • Turtle Points: 2
  • Member since Oct '17
I just went through this and mine basically fell on. However I know arbs are often a light press. Make sure it's going down evenly
knapp870
  • Turtle Points: 2
I will say probably the most crucial thing is to not tweak the copper air line out of the metal collar. That caused me hours of issues trying to solder it back air tight
Last post Jun 26, 2006, 11:07:27 PM
by Doc Holiday
Last post Jan 25, 2010, 03:13:14 PM
by 80YOTA4X4
Last post Mar 21, 2011, 08:28:56 AM
by 1slowhatch
Last post Jan 11, 2012, 08:18:11 PM
by Jaysen
Last post Feb 05, 2015, 06:36:11 PM
by flhtom
