Yep. Ive got a set of steel rockers. Coming your way.
Time to hit the head!Before anyone goes nuts on me I would like to say I did not do much, really very little and I also stayed quite conservative... And pre-emptively no I do not have a flow bench, experience with a flow bench, no access to a dyno, or any idea of what I am doing.
Nearly forgot about the rusty, crusty pilot bearing stuck in the end of my crank. So Napa due got me a made in Japan Nachi pilot bearing for $6.New moneys total: $454.42
If that was a single row timing chain, the wear would be halfway thru the block (even the Toyota one)...........
I assume you are talking about the torsioner.Why would a double row chain wear less than a single row chain? Gnarls.
Same pressure on chain, twice the surface area
You should of course have the timing cover machined with your block. I wasn't planning on decking the block, so I didn't send it in, but then the machinist decked it about .006"-.007" anyway. So what do you do with your too tall timing cover?
All of my rocker shafts are scored, grooved or otherwise out of tolerable spec, so I ordered up some DNJ rocker shafts (made in China) for $31.30. They mic out right and will help get the oil clearance back in line for the rockers. I think I may drill and chamfer the two extra oiling holes per rocker like the LCE shafts have.They look pretty good but the threaded mounting holes have some jaggers and the inside of the shafts are a bit rusty and dirty. I will be cleaning up the burrs and probably using some gun cleaning tools to get the rust out of the bores. For $30 I'm not going to complain.New total cabbage: $485.72
Excellent product evaluation! Thanks for more facts... less Bravo Sierra.I'm just curious.... what is the diameter of the oiling holes in the DNJ shafts compared to the LCE shafts? Also, how many thousands are the chamfers in the LCE shafts?Thanks,Gnarls.
Took a try at drilling a hole out on the end of one of the DNJ rocker shafts where it wouldn't matter. I have determined after about 5 minutes that these are made of some pretty hard stuff. I don't think I can drill extra oiling holes efficiently with normal tools. I think I would just mess them up if I tried so I am going to run these as is.The holes are the same size as stock, about 3/32". I have several sets of rocker shafts. Some have a bit more chamfer on the holes and some look just like these do. I am going to say they are good enough unless you want to buck up and buy the $200 LCE shafts.
Started by TRHS1980 Project Research and Build-Ups
Started by AR80Toy « 1 2 » Project Research and Build-Ups
Started by Crawlin4fun « 1 2 3 4 5 » Project Research and Build-Ups
Started by h0nke Project Research and Build-Ups
Started by Kyle20r4spd Project Research and Build-Ups
