What rings did you end going with
Earlier, you were at 19 hours. By my calculations, your weekend was 6.5 hours long.
Did inventory on rocker sets today. On set from an '83, aluminum, rockers in OK shape but the rocker shafts are really dug into. 2 sets from 1980 20r with steel rockers, one of which is really nasty and one set in good shape but so varnished up I can't get it apart without drilling out the screws.I started trying to hone the aluminum set but found that the bulkier aluminum rocker body does not allow a full pass on the stone so you can't really resurface the faces on a stone like I did with the steel rockers before. When I get home I'll drill the good steel ones apart and see how the shafts and all that are.
Im checking my stock of parts. I think I might have some more rocker arms for you. If I find some Ill send them to you.
Started by TRHS1980 Project Research and Build-Ups
Started by AR80Toy « 1 2 » Project Research and Build-Ups
Started by Crawlin4fun « 1 2 3 4 5 » Project Research and Build-Ups
Started by h0nke Project Research and Build-Ups
Started by Kyle20r4spd Project Research and Build-Ups
