Thanks for the wisdom. I roughly calculated out the difference in performance due to 2" taller tires, and, like you said, decided I need more engine tuning if it's going to run well. I am 90% sure the O2 sensor is bad. Burning coolant is supposed to do bad things to them, right? And I haven't the foggiest idea when it was last replaced. I need to look at timing and check plugs, too. But the fuel filter is new. I already replaced it and made a big difference. The PCV valve is shot but inaccessible and unavailable -- some invention will be needed there.Would someone mind educating me me on back pressure? I know nothing except that vehicles always "feel" more zippy when they don't have exhaust leaks.Tune, tune, tune! learn, learn learn!! I won't be happy until I can shift to 5th at 40 like the manual says.Lewis
Part of your performance issue may be due to how you are driving, Japanese engines tend to be high revving engines, and most of their usable power in stock form doesn't start until around 3k, 5th gear at 40mph in any of them, as in most cars, would make them perform horribly.Based on the gearing and diff gear(5.29 stock if correct), at 40mph w/29's your rpm's are about 2100, which is too low to have any performance due to its hp/trq #'s and where its power band is,at 60mph it would be about 3100rpm's.
JB WELD...LOL...... JB weld is good for 600d F... that exhaust manifold will get to 1000d plus in 5 minutes.... if it holds if would exceed the specs for JB Weld.
5.29 stock is correct. And it is stock as far as I know. 5th in 40 seems crazy to me. But it's what the manual says, so it should at least be possible to do. Right now, it's not.
Your comment about "Japanese engines tend to be high-revving engines" intrigues me. All I know about them is what I've learned from being around trucks powered by 22R/REs, 3RZs 1UZ-FEs, 3VZ-FEs and 5VZ-FEs, and I wouldn't characterize any of these as "high revving" from what I've seen. Also, it seems that revving high and lasting long are at odds with each other. Would you care to clue me in?
More impressions from a drive to town.I think that exhaust leak is really holding it back. You see, the manifold appears to have had coolant dumped on it while hot -- there are cracks everywhere and a couple reasonably sized holes. Also, while driving, there is a quiet mode and a loud mode -- the loud mode is when the exhaust leak gets too obnoxious from the engine having to pull hard. If I am driving down the highway, it feels pretty zippy until the engine gets just enough of a load to go into loud mode. Then I start losing speed and can hardly get moving again. It also tends to run well at the start of a drive, but badly after going at speed on the highway for a while.What do you all think? I know I need to replace the maintenance stuff, but does it sound like the manifold is also a problem?Thanks
This JB-weld experiment was well worthwhile, as I now have some actual evidence behind a hypothesis I've been working on for a while. My hypothesis is that the leak in the exhaust manifold lets stray oxygen into the exhaust pipe, which is sensed by the O2 sensor. This, in turn, would cause more fuel to be injected into the cylinders, resulting in all kinds of bad things.
Next up: ThermoSteel! Supposed to be good to 2000F and direct flame contact, so even derating it by 20% it might hold okay on my 500F exhaust manifold, for a while. Nothing would beat a good, new manifold or header, but $350 will buy 35 cans of thermosteel. If each one lasts only a year, that'll keep the manifold in trim for longer than the engine will keep running.
Started by johnyreb69 Project Research and Build-Ups
Started by ronezrocky Newbie Questions
Started by ag86IL Project Research and Build-Ups
Started by River Axle/Differential/Steering
Started by utherjorge « 1 2 » Project Research and Build-Ups
