Disconnect the O2 sensor.The ECU will go into open loop mode and throw a code. But it may be better than running with faulty information from the O2 sensor.
Don't get me wrong. I'd LOVE to try my hand at brazing, And I really wish this could be brazed and done right.However, I don't know how to braze, and don't have anything hotter than a plumber's torch. Besides, given my sheer incompetence, I'd probably burn a hole in the manifold before getting anything brazed. And that would be counterproductive, to say the least.
You don't need an Oxy mixture to braze with, propane would be fine, maybe MAP gas if you want a little hotter flame, and w/a little common sense you shouldn't have any concern melting a cast iron manifold. Since you have the torch already, pic up some rods and practice with some scrap steel, and go from there.
Wow, what kind of propane torch is this? I've tried brazing with that torch before, and it can't even do 3/4" thin-wall pipe.
If I had any assurance that it would be worth it in the end, I'd try that header. But I don't.
If I had any assurance that it would be worth it in the end, I'd try that header. But I don't.Wow, what kind of propane torch is this? I've tried brazing with that torch before, and it can't even do 3/4" thin-wall pipe.
Propane in air has a burn temp of 3500*, but lacks the BTU's so you need to make sure to block the flame from the wind
I took the Rocky to town and back the other day. It ran really well on the drive in and most of the way back. Then on the last hill on the highway, the needle began climbing up nearly to the danger zone (from 3/4 of the way there). I turned the heater on full blast and struggled to the top of the hill, fighting to make the thing even move. Nearly at the top, the "check engine" light came on. I coasted down to the bottom where my driveway starts, parked, and walked the last mile home. It was a good walk. Later, I read the code: "Rich mixture". I am discouraged. The water pump is good, the radiator is clean, and the thermostat is almost new. None of the hoses are collapsed. I just replaced the head gasket. The fan belt was loose, but not squealing, so I assume it was still hanging in there. The fan clutch was dismantled and shown to be underperforming. It's now been refurbished with some heavy-weight gear oil. However, based on what happened, I strongly suspect that the HG is blown again due to frequent running at 200-220F and close to the danger zone on the gauge. Running hot when (but only when) the engine is asked to work hard is almost diagnostic for a leak between a coolant passage and combustion chamber, right? Especially given the number of other cooling system components known to be good?Not only do I have cooling problems, that "rich mixture" thing has me worried. It suggests that I've damaged something else really badly while I was at it.WARFS has some good tech and knowledgable people. If only they'd let me join...
As for resurfacing the head, I think my little milling machine might be up to the task... maybe.
So, I went to put on my new timing belt today and... it won't fit. No matter what I did with the tensioner, the belt stayed loose.I sat down to get my facts together for a polite email to RockAuto asking them to correct the problem. These are the facts:Fact 1: I have a belt that came off the Rocky: it fit, and has 93 teeth.Fact 2: The belt I received has 95 teeth.Fact 3: All the belts that RockAuto sells for the Rocky have 95 teeth (if specified at all)Fact 4: The Daihatsu Charade came with a 1.3 liter engine, which (according to RockAuto) takes a 93 tooth timing belt.Conclusion: Somebody either put a straight-up Charade engine in this thing, or some strange hybrid. RockAuto cannot fix that for me. GRRRRRRRRRRRRRRRRRRRRRR.
There is no way that there is a Charade engine in there.
Looking at the '90 its hp/trq #'s, you should be shifting between 4500-5k,Based on the gearing and diff gear(5.29 stock if correct), at 40mph w/29's your rpm's are about 2100, which is too low to have any performance due to its hp/trq #'s and where its power band is,at 60mph it would be about 3100rpm's.
Started by johnyreb69 Project Research and Build-Ups
Started by ronezrocky Newbie Questions
Started by ag86IL Project Research and Build-Ups
Started by River Axle/Differential/Steering
Started by utherjorge « 1 2 » Project Research and Build-Ups
