Author Topic: Shifters hitting eachother?  (Read 1480 times)
MrFatEggs
  • Member since Apr '17
« on: Jul 27, 2017, 05:07:04 PM »
I have a g52 that I'm going to swap into my truck and get rid of the loud l52, but the shifters are hitting each Other? I shifted it to 2nd gear, and the shifter crashes into the transfer case shifter. Is the wrong shifter on the transmission? Does anyone know what is going on? I attached a picture.
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
Re: Shifters hitting eachother?
« Reply #1 on: Jul 27, 2017, 05:38:53 PM »
Have you tried flipping the t case base
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
« Reply #2 on: Jul 27, 2017, 05:58:34 PM »
I think there are several different t-case lever bends/models. Bend it as you need it.
R.DesJardin
Plainview
  • Turtle Points: 175
  • Member since May '14
« Reply #3 on: Aug 05, 2017, 08:37:52 PM »
I have this problem, sort of, on both of mine and they're both factory stock.
On mine it only happens when the T-case is in 4-low and they don't "crash into" each other, it's just light "side-swipe" contact but enough that sometimes it knocks the t-case lever back to neutral which is no fun at all when climbing hills...!
On the xtra cab truck which only has 149K on it, I installed the Marline delrin bushings and that pretty much solved it.  I put those bushings in the standard cab and it made it better but with 230K on the tranny there was still enough slop that it was still happening occasionally.  So I put a W56 in it and problem solved (levers are different on those).
If you're having major interference you probably have the wrong shifter or as suggested the T-case shifter could be backwards.
'84 Xtra Cab Project:
http://board.marlincrawler.com/index.php?topic=100651.new#new
Parts Wanted:
- Un-cracked dash pad (do they exist?)
Toybrota
  • Turtle Points: 166
  • Male Posts: 764
  • Member since Dec '15
    • Buy me some coffee
« Reply #4 on: Aug 13, 2017, 10:30:10 PM »
Old thread, but definitely the wrong shifters. The bend is the problem, the lever should just be straight up (it is on my G52)
Sent from my Nexus 6P using Tapatalk
Last post May 31, 2007, 09:01:14 AM
by Gewehr43
Last post Jun 04, 2007, 05:21:00 AM
by jimbo74
Last post Jul 20, 2009, 09:45:35 PM
by *FFC*
Last post Apr 12, 2014, 06:16:17 PM
by HogCanyonHopper
Last post Oct 05, 2015, 04:47:37 PM
by Mudder
