Author Topic: Distributor install help please  (Read 1256 times)
MrFatEggs
  • Member since Apr '17
« on: Jul 11, 2017, 03:10:22 PM »
I ran across some confusion when I was about to install my distributor. I'm installing it into an almost fully built hybrid motor that's never been ran before. With that said, I've always just replaced a distributor, but this engine has not had a distributor in it so I'm not exactly sure where the crank and came should be when I install it. I currently have it on 0 tdc with the cam at the position in the pictures. Am I good to drop the distributor in and have the rotor point to cylinder 1? Or do I need to turn the cam?
I've also head that hybrids run best on certain timing advancements and what not, any info on that as well would be much appreciated.
Here's the specs of the motor.
20r head
Delta 272 433 lift cam
Weber 38 outlaw
Oversized valves
Aluminum rockers
22r block bored 40 over
40 over pistons
Egr delete
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: Distributor install help please
« Reply #1 on: Jul 11, 2017, 03:23:48 PM »
Yes just drop it in so it ends up pointed at the #1 spot on the rotor.  It always fools me on a fresh engine and I put it off 1 tooth advanced but you will figure it out :).
My cam timing ended up liking about 1 degree retarded, I think my ignition advance is like 8 degrees BTDC right now but you will have to feel that one out for yourself.
– Steve McQueen
MrFatEggs [OP]
« Reply #2 on: Jul 11, 2017, 04:17:09 PM »
Thanks!
Last post Oct 05, 2004, 05:45:19 PM
by burl4x4
Last post Dec 04, 2006, 06:27:29 PM
by DeMented Toys
Last post Nov 30, 2006, 11:31:35 AM
by badwheelr
Last post Mar 22, 2007, 12:06:33 AM
by kneedownnate
Last post May 31, 2010, 05:53:06 PM
by OOPS
