That's wear from the front seal.Just set the depth of the new seal so it's on new section of the pulley.If that's not possible, there's a sleeve you can buy to put on the pulley so it's all a fresh surface.
I don't think there is much "play" in the seal position.
There is when the new seal is thinner than the original.........
I'm putting the harmonic balancer onto my engine and I noticed grooves where it seals on the front main seal. Are those suppose to be there? I attached a photo.
Started by cmilliron General 4WD Discussion
Started by i_luv_my_truck Project Research and Build-Ups
Started by festus Toyota Pickup/4Runner Tech 1979-95
Started by 84TanToy Parts Wanted
Started by MrFatEggs Engine
