It's about 70 here and all my carbs have the choke closed with spring tension. It could be just bound up and crusty, or just bad all together. You will be glad you got the spare carb.
The accelerator pump should give you a cross between a squirt and a mist, pretty well pronounced it if it's good.
UPDATE 4-25-17:My new-to-me carb arrived in the mail today. Here what I've seen on a first glance and casual go-over.The good: - All the parts seem to be there. This is in contrast to my current carb, which is definitely NOT complete. - It looks as if it's been rebuilt recently, so I may not need a rebuild kit when I take things off to look. - The choke acts a lot more functional than mine. The bad: - The fast-idle cam and cam linkage is present but non-functional; This is because the spring that engages it needed one more turn before it went back on. - The secondary air valve is different than my current carb -- it only closes completely when the throttle linkage is moved to simulate gas pedal pump. It never opens completely, either. My current one is closed by default, but can be opened completely and will re-close with spring tension. - The throttle linkage is much stiffer than it should be. It turns easily enough, but takes several seconds to spring back to "closed". - The carb is full of old, old gasoline -- so old that it smells more like motor oil.The ugly: - The acceleration pump is frozen solid -- won't budge. Fortunately, it is frozen in the position that lets the throttle operate, but this will have to be repaired somehow.Now, as mentioned there are some things different between these two carbs. Some, I know which one is as should be, but some I do not. I think the linkage on mine that just dangles loose is part of the fast idle setup; It sure doesn't dangle loose on this one. However, some things are less clear.The questions:How should that secondary air valve be adjusted, anyway?Is there any way to fix the acceleration pump?Is oil lubricant good enough, or will this mix with the gasoline?How much dis-assembly and re-assembly can I get away with before I have to buy a rebuild kit?
Sorry for horrible autocorrect grammar ^^ Sent from my D5803 using Tapatalk
Acceleration pump. Very easy to remove the 4 screws and pop out off. The rebuild kits come with a new diaphragm/piston and boot. The pump arm connected to the housing should move freely and I don't see any reason with lubricating that. No gas should contact it. The whole thing is driven open by a spring so that should be there as well.
'Nuther update 4-27-17..... Can I pull the carburetor, look, adjust, and replace it without replacing the thick gasket underneath it? ....
On the 22R with a HAC, I believe the HAC mechanically senses barometric pressure more at sea level, less at 5,500 feet elevation. I dont believe the HAC can compensate for air density, relative humidity, or ambient air temperature.
Started by parshal Toyota Pickup/4Runner Tech 1979-95
Started by Slobbermouth Toyota Pickup/4Runner Tech 1979-95
Started by JoeShmo65 Toyota Pickup/4Runner Tech 1979-95
Started by toby Toyota Pickup/4Runner Tech 1979-95
Started by 84_yota_4wd Toyota Pickup/4Runner Tech 1979-95
