Author Topic: My 87 pickup SAS Build  (Read 20152 times)
epantano
  • Turtle Points: 275
  • Member since Aug '16
« on: Mar 09, 2017, 06:19:16 PM »
Hi All,
I've been reading a lot of info on here trying to get prepared for my solid axle swap on my pickup. Finally i scored a nice 85 axle for a few hundred off craigslist. These things are getting hard to find!
I ended up piecing my own kit together over the last few months as paychecks come in.
I got new,
Marlin Springs 4", Allpro high steer, ubolt flip kit, shock hoops, shocks.
I fabricated my own front spring hanger, cut some DOM tubing for the holes that need to be cut through the frame. I templated the length from a kit my buddy had purchased. Ended up being cheap since i had the right size tube for a project we have going at work. Got the front wheel spacers from a friend who bought them and didnt need them, so i paid $20 for those. All the grease able 18M bolts I purchased from a surplus store, for half the cost online.
I rebuilt the axle all new seals, bearings, gaskets, studs, etc. This took me a while to do as I had never built one before. However, youtube provided some answers and this forum gave me the rest!  :cheese:
I'm at the point now where I have the axle mounted and everything hooked up. The issue I am having now is when I have the truck on the ground it has issues turning all the way to the drivers side. Its a good half an inch away from the bumpstop.... When i lift it off the ground Im able to turn it all the way. Do you guys thinks this has something to do with my alignment? Or something else? I can't see it binding on anything or hitting bumpstops on the other side. Also I added plating to my steering box and now it seem to be binding a hair when in the middle. I can still turn lock to lock when its off the ground but it feels tight when its around center... Any ideas on that?
Any advice on this would be appreciated. Thanks guys!
Future plans (As money allows)
Rear suspension - I have the spring(Got from marlin) and an E locker i found at a junkyard. Need to piece together the rest. Likely will fabricate the hangers.
Front locker. (Still trying to figure out which one would be best for me)
Dual Transfer case (When will these be in stock again!) Maybe ill have to build one...
3RZ swap
Hydro assist ( I have manual steering right now  :-\)
PS: Trying to figure out how to put pictures...
epantano [OP]
Re: My 87 pickup SAS Build
« Reply #1 on: Mar 10, 2017, 06:33:34 AM »
Because we all like pictures, here you go!
Time to chop the IFS
All chopped
Welded on a clone of the Ruffstuff IFS frame stiffner. My buddy never installed his and so I copied it and got a sheet of 3/8" steel and cut it using a plasma torch.
Cut through the frame and welded in the tubes for the shackles.
Shock hoops welded in.
Axle work
Air compressor wasn't good enough for my buddys plasma cutter, so we made this and connected two to it.
Make sure it all lines up
Shackle Angle its about 90. It should settle a bit with these new springs.
How it currently sits
The car party welding day lol
dustingro
  • Male Posts: 16
  • Member since Aug '12
« Reply #2 on: Mar 12, 2017, 05:19:35 PM »
I'd say your drag link is a bit long and the steering box is maxing out. Try shortening it to equalize travel and pulling steering wheel and put it on straight.
Sent from my SM-G920V using Tapatalk
'85 long/flat bed ,225k 22RE, marlin built W56, duals with 2.28/4.7, 35" Toyos
(coming soon) mother in law's 92 runner V6/5spd
epantano [OP]
« Reply #3 on: Mar 13, 2017, 08:09:39 AM »
Hey Dustingro
So I just need to pull off the drag link and screw the ends in further? I didn't seem like the box was maxing out, when I had the weight off​ the wheel it was able to travel further.
I'll try it out and get back and update my results.
epantano [OP]
« Reply #4 on: Mar 15, 2017, 08:10:29 PM »
Okay guys,
Need some help. Ive been messing with the steering for a few days now.
I double checked my alignment seems perfect. Exactly 1/8" toe in.
I checked the box made sure im not maxing out. Here is how close to the bump stops i am when tires are off the ground
And on the ground
Ive tightened the drag link in nearly all the way and I cant seem to figure out what is wrong...
Anyone have any ideas?  :hammer:
epantano [OP]
« Reply #5 on: Mar 16, 2017, 03:55:01 PM »
Bump.
Anyone ??  :confused:
joeyf
  • Turtle Points: 848
  • Member since Dec '06
« Reply #6 on: Mar 16, 2017, 05:42:43 PM »
Try turning the truck on, slowly drive and turn.
epantano [OP]
« Reply #7 on: Mar 16, 2017, 05:46:50 PM »
I have driven it. Same issue with it not turning all the way...
joeyf
« Reply #8 on: Mar 16, 2017, 05:59:58 PM »
Maybe the knuckle shims are off. Any up and down play in the knuckles.
epantano [OP]
« Reply #9 on: Mar 16, 2017, 06:31:39 PM »
Just checked the knuckles are nice and tight no up and down play at all. The entire axle has been rebuilt before it was installed.
Sent from my Nexus 6P using Tapatalk
epantano [OP]
« Reply #10 on: Mar 19, 2017, 11:59:22 AM »
Bump. Still looking for help anyone had this issue?
daniresch
  • Turtle Points: 930
  • Male Posts: 761
  • Member since Apr '11
« Reply #11 on: Mar 20, 2017, 09:49:47 PM »
Have you checked the steering stop on the front of the axle, on the other end of the axle?
daniresch
  • Male Posts: 761
« Reply #12 on: Mar 20, 2017, 09:56:17 PM »
Right here:
Check all 4 steering stops  :thumbs:
epantano [OP]
« Reply #13 on: Mar 21, 2017, 06:32:07 PM »
Yes i checked both sides front and back. It doesn't hit any bumpstops when on the ground and has about the same gap on both sides when turned to the drivers side, roughly 3/4". It is very close to the bumpstop when turning to the passenger side maybe 1/4". See pictures above.
When its in the air and no weight is on the tires, it can turn all the way and hits both bumpstop in each direction. No gap on front or back. Thats why I am so stumped, and so i assumed it was the drag link that needed adjusting.
Anyhow, I havent been working on it this past week, as I pulled the rear axle and have started working on the rear long travel kit and installing the new locker. Hoping someone can shed some light on this issue....
Thanks guys.
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #14 on: Mar 21, 2017, 07:06:02 PM »
Is the drag link rubbing on the pitman arm, the pic of steering box bolted in looks like it has strange angle on pitman arm
daniresch
  • Male Posts: 761
« Reply #15 on: Mar 21, 2017, 08:39:32 PM »
Can you post some pictures of the steering box bolted on the frame, pitman arm, drag link and tie rod?
epantano [OP]
« Reply #16 on: Mar 25, 2017, 02:01:44 PM »
I'm 99% sure it is not rubbing, i double checked it and no paint is missing and had a friend watch it while it turned.
Daniresch here are the pictures. Let me know if you need more pics. Thanks for the help guys.
daniresch
  • Male Posts: 761
« Reply #17 on: Mar 25, 2017, 10:34:29 PM »
Disconnect the driver side tie rod end from the high steer arms and feel how the wheels turns back and fourth. I want to eliminate birfield binding and trunnion bearing preload installation mistakes. I mainly want to focus on the fact it steers fine when there is no weight on the wheels.
Other things to consider: As Ovrarok mentioned, it looks like your pitman arm is going to smack into your tierod when the driver side wheel travels up. We need a better picture of how parallel the tierod and draglink are. Two ways to fix this, shorter pitman arm (skys-offroad has a good option) or move your steering box further forward.
Also, you need to swap your u-bolts out on the driver side axle for square ones made for the 1985 axle.
epantano [OP]
« Reply #18 on: Mar 27, 2017, 11:42:46 AM »
Okay, so i haven't pulled the tie rod end off just yet, But when i lift the front end it turns easily and smoothly and all the way to each bumpstop. Ill pull it off this weekend and check it again. How would i know if it was binding on the birf or if the bearing preload was done incorrectly?
And yes you guys are definitely right my pitman arm is to long it and it will hit. Thanks for the catch. It came with the high steer kit i got, so i assumed it was okay. So ill have to order the one from sky.
For the Ubolts, i've called around to a few places and cant seem to source the square ones. Any ideas where i would be able to get those?
thanks!
epantano [OP]
« Reply #19 on: Mar 30, 2017, 11:21:34 AM »
Another question:
If I got with the shorter pitman arm does it effect my turning in any way?
OVRAROK
  • Male Posts: 3,506
« Reply #20 on: Mar 30, 2017, 11:38:54 AM »
 :headscratch: wish I could answer, but when I did my sas. I went with flat pitman arm. my steering box is in a little different location as well.
OVRAROK
  • Male Posts: 3,506
« Reply #21 on: Mar 30, 2017, 11:43:37 AM »
Sent from my HTC One_M8 using Tapatalk
epantano [OP]
« Reply #22 on: Mar 31, 2017, 09:32:10 AM »
Yeah I think if I use a flat one it would hit my frame. But a short 3/4" drop pitman should hopefully be the solution for that issue.
What year is your frame? And did you relocate the box forward a good bit?
OVRAROK
  • Male Posts: 3,506
« Reply #23 on: Mar 31, 2017, 09:37:51 AM »
87 frames. And yes, I pushed it forward
epantano [OP]
« Reply #24 on: Mar 31, 2017, 09:42:49 AM »
Mine is an 87 too. Maybe it would be better to just relocate it further forward. Did you get sleeves to weld through the frame when you did that? Also how did you extend the shaft from the steering wheel?
OVRAROK
  • Male Posts: 3,506
« Reply #25 on: Mar 31, 2017, 11:52:21 AM »
yes, there are tubes thru frame, and there are 2 plastic pins on shaft, I melted them out, get your length, then drilled new holes
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #26 on: Mar 31, 2017, 08:42:57 PM »
Here's a bit of a random observation: Are you front shocks too long?  It looks to me like they might bottom out long before your front suspension does.  Are those 14" shocks?  I'm pretty sure I'm only running 12".
Willard
  • Turtle Points: 1608
  • Male Posts: 627
  • Member since Dec '14
« Reply #27 on: Mar 31, 2017, 09:57:48 PM »
Shocks create a perfect bump stop.....ask me how I know lol
blackdiamond
  • Male Posts: 5,052
« Reply #28 on: Apr 01, 2017, 03:02:44 PM »
When I was still running Bilstein shocks they became bump stops as I was able to bottom them out often. I did care for the abrupt end to my suspension, it was not much different than coming down on the rear bumper.
epantano [OP]
« Reply #29 on: Apr 04, 2017, 10:48:12 AM »
They are the 5125 Series Bilstein shocks. They are 13.5" collapsed. I still need to add my bump stops anyhow.
Last post Mar 23, 2006, 11:11:56 PM
by bustatoy
Last post Dec 20, 2007, 10:44:36 PM
by fatt_matt
Last post Apr 04, 2015, 11:20:52 PM
by Jason E.
Last post Jul 03, 2013, 03:48:07 PM
by tyes
Last post Mar 29, 2017, 08:52:32 AM
by epantano
