Author Topic: ToyBrota's 85 Xtracab Build up.  (Read 71361 times)
joeyf
  • Turtle Points: 848
  • Member since Dec '06
Re: ToyBrota's 85 Xtracab Build up.
« Reply #90 on: Oct 01, 2017, 10:03:51 PM »
You could us plumbing but it would probably last just as long as jb weld, brazing rod would be the best thing to use.
Toybrota [OP]
  • Turtle Points: 166
  • Male Posts: 764
  • Member since Dec '15
    • Buy me some coffee
« Reply #91 on: Oct 01, 2017, 10:05:23 PM »
Okay cool, I'll get on that tomorrow. Probably gonna have to drain it again. I'm pretty good at soldering and some principles carry over.
Sent from my Nexus 6P using Tapatalk
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
« Reply #92 on: Oct 01, 2017, 10:16:22 PM »
Just swap to a decent v6 radiator while its all out. Putting all this time into a 4cyl is lame. It takes like 3 minutes to redrill holes.
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,219
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #93 on: Oct 02, 2017, 04:20:58 AM »
There is more to it than just 3 minutes.  The V-6 radiator may have different dimensions, causing a fit problem.
Then there's the cost... 300k, do you want to donate a new V-6 radiator?
Gnarls.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #94 on: Oct 02, 2017, 07:20:26 AM »
Aluminum after market v6 radiator less than 150 on ebay. Bolts difectly in place.
01 double cab hunting truck
06 tacoma street truck
Toybrota [OP]
  • Male Posts: 764
« Reply #95 on: Oct 02, 2017, 09:32:13 AM »
I'll look into that, I might try the plumbing solder fix. My heater does work now! Works pretty darn good too
300k
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #96 on: Oct 02, 2017, 10:35:18 AM »
Gnarls.
Theres a video on YouTube...pretty straight forward. Clamp your 4cyl rad to the v6 rad with the radiator caps even with each other, use paint pen to mark where the holes are on the 4cyl, unclamp, drill. Faster than messing with solder.
As for price, go to a junkyard and grab one out of a 2nd gen 4runner.
Toybrota [OP]
  • Male Posts: 764
« Reply #97 on: Oct 02, 2017, 10:37:15 AM »
I'll have to see what the junk yard has, I assume the V6 rad has better cooling.... Right? Only makes sense. I know there's no such thing as a dumb question but that one felt dumb.
There's always 4Runners at my local pick n pull.
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,141
  • Member since Sep '08
« Reply #98 on: Oct 02, 2017, 10:41:58 AM »
I have fixed a couple with solder and it holds up fine. I think it was just 50/50 tin/lead solder? I use mapp gas, I burned a hole in one with an oxy acetylene torch one time. make sure to get it clean, clean, clean.
Toybrota [OP]
  • Male Posts: 764
« Reply #99 on: Oct 02, 2017, 10:42:32 AM »
There's a few 90's 4Runner near me. I'd really like a new one, because with my luck in pick n pull, I'd put it in, and find out it leaks...
Maybe I'll try the solder thing first, if that doesn't work then I'll get a junk one.
300k
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #100 on: Oct 02, 2017, 10:45:36 AM »
Its a junkyard upgrade to a 3 core instead of a 2 core. It depends on your climate. If youre in the desert or a mildly warm place with a lot of hills, V6 all the way.  If it gets real cold, your heater might not be as warm.
Toybrota [OP]
  • Male Posts: 764
« Reply #101 on: Oct 02, 2017, 10:47:03 AM »
I live in Salt Lake, and it's getting pretty cold. I'll just stick to the stock one. If I can't fix it, I'll just get a new one.
Toybrota [OP]
  • Male Posts: 764
« Reply #102 on: Oct 03, 2017, 10:07:38 AM »
So I got a great build idea while I was in the shower (best ideas come to me this way)
Hear me out. I wanna take a Toyota one ton full float dually axle, and put it under my truck, and put 5.29's with 33X10.5s. Dually 33's
Why you may ask? Because doesn't it seem kinda bad ass? Low gearing with those tires, could actually pull stuff. And a flat bed.
Anyways, just a dumb idea I had. Thought it would be sick.
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
  • Trying to equal the wonderful one-hoss shay
« Reply #103 on: Oct 03, 2017, 10:25:56 AM »
I say, do it. But I also say, think long and hard before doing it with a G52 in your truck.
By all I hear, the G52 was almost the second weakest transmission Toyota ever put in a truck. At least, I'd put a W56 in there before getting too crazy with what I pulled. Better yet, find a R150F/R151F and use a 22RTE bell housing to bolt it up to your motor.
This is purely my opinion based on things I have read. Perhaps somebody with actual experience of Toyota transmission strengths would like to weigh in?
Lewis
Toybrota [OP]
  • Male Posts: 764
« Reply #104 on: Oct 03, 2017, 10:27:26 AM »
Lewis
Exactly, the G52 is weak. I'm on my second one.
It's purely an idea at the moment, I think it would be overkill and awesome.
Toybrota [OP]
  • Male Posts: 764
« Reply #105 on: Oct 10, 2017, 10:33:41 AM »
Anyone wanna help me identify this noise? It's so weird. Sorry for the noisy valves. I gave up caring with the damn aluminum rockers.
https://youtu.be/dTi8Ir_HwGQ
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #106 on: Oct 10, 2017, 10:39:28 AM »
Take the belt off and see if the noise is still there. I think it could be the upper idler bearing.
after the belt is off spin everything with your hand and see if you can make out any noise.
I am 1/5th of Perfect Fit
EASYRYDERDANGER
  • Turtle Points: 1856
  • Male Posts: 215
  • Member since Jul '06
« Reply #107 on: Oct 10, 2017, 10:41:40 AM »
2nd this
Sent from my XT1585 using Tapatalk
Toybrota [OP]
  • Male Posts: 764
« Reply #108 on: Oct 10, 2017, 10:55:31 AM »
Did that, took off the power steering belt. Noise persists.
Removed the water pump and alternator belt (only ran for 15 seconds) noise goes away.
Water pump spins freely as it should. Alternator on the other hand, is obviously making the noise. I just replaced it too. Parts store stuff is garbage.
It's been making noises since I put it in, but it's been getting worse. Maybe a few shots of WD40 into it might displace any water or whatever.
EASYRYDERDANGER
  • Male Posts: 215
« Reply #109 on: Oct 10, 2017, 10:57:58 AM »
Was belt on too tight?
:)bestgen4runner
  • Male Posts: 1,796
« Reply #110 on: Oct 10, 2017, 10:59:18 AM »
Try compressed air and blowing it into the Alt. Don't put WD in there.
redneckcustoms13
  • Male Posts: 2,513
« Reply #111 on: Oct 10, 2017, 11:00:14 AM »
I doubt its a moisture issue. What your dealing with more than likely is cheap bearingsfrom the parts house cheapo rebuild.
Toybrota [OP]
  • Male Posts: 764
« Reply #112 on: Oct 10, 2017, 11:07:28 AM »
Exactly what I'm thinking. The belt is on looser than when I took it off, still has good play. I'd kill for a denso alternator. But the money on that....
Lewis Hein
  • Shoutbox Ban
« Reply #113 on: Oct 10, 2017, 11:12:40 AM »
Try eBay. I got a used Denso alternator for $30 there... New would be better, but I bet a good used Denso would outlast a parts store reman unit.
redneckcustoms13
  • Male Posts: 2,513
« Reply #114 on: Oct 10, 2017, 11:22:35 AM »
Have any u pull it yards around? I have had my factory densos rebuilt at a local shop and requested timken bearings be installed.
redneckcustoms13
  • Male Posts: 2,513
Toybrota [OP]
  • Male Posts: 764
« Reply #116 on: Oct 10, 2017, 11:29:37 AM »
Check with this guy.
http://board.marlincrawler.com/index.php?topic=102455.0
Alrighty will do, I got side tracked with a coolant hose leak. I definitely want a nice alternator when I build my motor.
Toybrota [OP]
  • Male Posts: 764
« Reply #117 on: Oct 10, 2017, 12:31:40 PM »
Don't think so, still makes noise with it tight and loose.
Toybrota [OP]
  • Male Posts: 764
« Reply #118 on: Oct 10, 2017, 12:35:05 PM »
Okay, side tracked with a more important issue.
The water outlet on the timing cover that is for the heater hose leaks, I did the timing chain and cover about 10K miles ago, in fact, a bolt was MISSING from the outlet pipe.
Walking right now to the auto parts store (walk of shame...) To get some silicone sealer and a gasket kit for the timing cover. The thing is, the outlet shares the gasket with the timing cover gasket on the right side, I'm not tearing the timing cover off, so I plan to cut that section of gasket out and replace it with a new cut section with silicone smeared on both sides. What do you think?
Toybrota [OP]
  • Male Posts: 764
« Reply #119 on: Oct 10, 2017, 12:57:24 PM »
Hopefully I can get this thing back in service in a couple hours.
