...Went and installed carpet ....It was a pain to cut the carpet out to the needed shape, but I did it.
It's looking good! Did you buy an aftermarket carpet kit formed for the truck? Gnarls.
LEDs are definitely worth it.http://board.marlincrawler.com/index.php?topic=42051
The sender for the gauge and the sender for light use 2 different wires. If you just swapped the sender and used the same wire then you may need to look for the correct wire.
Well I could get it to work, the sender uses the same wire per the FSM, pin 3 on connector A. Sent from my Nexus 6P using Tapatalk
Kinda off topic, but does anyone have tips for preventing people from messing with your winch? I was at a highschool dance tonight, only to come out to my winch cable wrapped around my truck. All of it unspooled, and kinked. Which we all know is great to steel cable. I use my winch every once in awhile so I wanna keep it on my truck, but I need a way to prevent people from messing with the free spooling. Thanks, many frustrations right now. Sent from my Nexus 6P using Tapatalk
that's rude. did the parking lot have cameras? that person should be kicked in the head for messing with other peoples
It does, I mean, it's just a cable but that chances of it getting kinked more is not making me very happy. It definitely has more kinks in it. Sent from my Nexus 6P using Tapatalk
I pull mine so tight that it cannot be free spooled. I have to reverse it before it can be free spooled. This was a common issue when I was in school.
man people are so childish. yank 'er tight and padlock it.
Or just pull the drive shaft out and set it in the back
