Hey sassparilla_kid,Wow… nice start to a rebuild. I’m very interested in following your project. Perhaps from a practical rather than aesthetics point of view, painting the block, rocker cover, and oil pan a light color is very smart. After I painted mine black, I realized I screwed up. I'm not saying you will have anything leaking when you are done with the assembly - but the light colors will simply allow you to see any potential leaks way easier. To me seeing oil or coolant leaks on a black block or oil pan is very difficult, and I'd much rather find them on the block BEFORE discovering them on my driveway. The lighter colors also make it easier to get the engine clean during degreasing and power washing. If I do another engine rebuild, I will paint light colors on engine and engine bay, including front frame rails. On the silver paint, I would give it a coat of clear. Silver paint is heavy metal and has a more textured surface, the clear coat will help protect the paint and make it easier to clean… that’s just my experience. Gnarls.
Looking good! I like the LCE stuff. You are going to love that cam. I have been telling the other boys on here to get it but they are cheap and don't often listen.
...You are going to love that cam. I have been telling the other boys on here to get it but they are cheap and don't often listen.
sassparilla_kid,I am very curious how that cam works in your rebuild. I have compared it with other 22 cams in my DD.Is there any particular thing that made you decide on that camshaft?Thanks,Gnarls.
Evidently I either wasn't paying attention or forgot where all of the timing cover bolts went and also what I did with them so I gotta order some more...
Are you aware that there are two (2) bolts that will not get installed through the timing chain cover at the time you are bolting on the timing chain cover?The one on the passenger side, if you have AC, for the AC bracket. And, the one on the driver's side for the alternator adjuster bracket.You should be using a thin blade screwdriver to measure every single bolt hole and corresponding bolt so you know exactly the depth that each bolt will go into the block.I'm not inferring that you don't already know, but I'm just flashing back to the time I spent bolting on the t-chain cover. Gnarls.
...they're covered in grease and grit I don't feel like cleaning)...
Greasy parts don't rust So I don't clean them until I'm ready for them.
...Curios if anybody else has used a crank scraper on their build and if so was there a noticeable difference?
Just curious.... why do you think you need a crank scaper? What do you think it will do?What top RPMs do you plan to use in this engine?Gnarls.
A lot of it was curiosity and figured why not since it's all apart. A few semesters ago I took a class (I think it was international quality standards or something) and among the different quality improvement practices we learned about the Toyota (ironic, huh) method kind of centered on the fact that it's easier to make 100 1% increases than it is to make a single 100% increase, so that's kind of my thoughts with this build. I'm hoping a lot of the smaller things add up (lighter hypereutectic pistons vs cast, lighter h-beam chromoly rods, crank scraper, etc), but in case they don't it still has a better cam and is gonna get some headers too Sent from my SM-G930V using Tapatalk
Interesting...Gnarls.
What power, RPM range, peak torque and peak HP are you designing this build for?If you are running in Fresno, CA, and averaging a 300 foot elevation, your engine will feel good about that.I agree, and I have experienced, that very small changes can be “felt” by your butt dyno. Those small changes in performance have been most noticeable in my 22R. Performance-seeking changes in my 22RE’s have not been as noticeable. I believe H8PVMNT has clearly demonstrated that very small changes in a carb’d engine can be significant.Crankshaft scrapers are relatively inexpensive, however, I don’t believe a SuperFlo 902S engine dyno would record the change in torque in a stock 22RE, however it might record the difference between 5w-20 vs 20w-50. Scrapers also are known to be more tricky to seal up. Regarding lubricity issues, I have not read about any serious problems with a 22 in typical 4-wheeling activities.When it comes to changes in a 22RE, first, MammaECU will control and limit many changes, including AFR. The stock 22RE injectors will limit AF. Volumetric Efficiency are THE two big words when it comes to engine performance and power… so intake, head, cam, and exhaust is most often the main focus.If you are wanting to tweak and tune for incremental power, and I’m a big fan of getting the most out of our little engines, there are known factors to help. Super tuning a 22RE and all its sensors is very important. Beyond that, motor oil and gear oil viscosity can be parasitic, along with other engine components that induce drag– NASCAR engines typically run 0w motor oil and electric water pumps, for example.That’s just my very limited experience with Toyota 22s. Gnarls.
Also, new flywheel and clutch kit are on their way, so depending on what time they come in on friday I should hopefully be able to get them to the machine shop to have the flywheel and pressure plate balanced (the machine shop is in the same building as the Napa I ordered them from haha
Hey sassparilla_kid,Whose clutch kit and flywheel did you order?I am very curious to learn how much, if any, the machine shop that does the balance on the flywheel and pressure plate, will discover what it takes to balance them. It would also be nice to know to how many grams they balance to and what balancing equipment they use?Thanks,Gnarls.
Started by alfio Parts For Sale
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by gotxqss Parts Wanted
Started by 85-4roller Rigs For Sale
Started by OVRAROK Parts For Sale
