Author Topic: 22re full rebuild  (Read 40737 times)
sassparilla_kid
  • Turtle Points: -9
  • Male Posts: 67
  • Member since Feb '17
Re: 22re full rebuild
« Reply #60 on: Mar 18, 2017, 07:30:36 PM »
I dig I dig
'86 4X4 turbo turd pickup (soon to be non-turbo)
'17 Tacoma SR 4X4 (access cab, 4cyl, 5 speed)
sassparilla_kid [OP]
  • Turtle Points: -9
  • Male Posts: 67
« Reply #61 on: Apr 16, 2017, 08:24:53 PM »
Got the engine mostly torn down today! Time to start ordering new parts I guess
fireitup
  • Turtle Points: 530
« Reply #62 on: Apr 22, 2017, 07:42:05 AM »
Pictures! :)
Sent from my D5803 using Tapatalk
82 Pickup - 22R : OME NitroChargers/Springs : Timing Chain @ 180K
  • Turtle Points: -9
  • Male Posts: 67
« Reply #63 on: Apr 22, 2017, 09:08:28 PM »
Okay here's the truck
Jarhead
  • Turtle Points: 435
  • Member since Jul '12
« Reply #64 on: Apr 22, 2017, 09:24:55 PM »
Wow I was actually thinking I wanted to put a turbo in my 22re 4runner. But after all the replies on the thread I posted and these I'll stick to what I have for now.
  • Turtle Points: -9
  • Male Posts: 67
« Reply #65 on: Apr 23, 2017, 09:34:49 AM »
Yeah for me the extra 15hp isn't worth the hassle of a turbo, although if I lived someplace other than California and didn't have to deal with smog laws I might keep it but run it with megasquirt to get all of it's potential
  • Turtle Points: -9
  • Male Posts: 67
« Reply #66 on: Apr 23, 2017, 09:39:18 AM »
More pictures!
Parts stockpile
Rebuilt head
And one torn down 22re
  • Turtle Points: -9
  • Male Posts: 67
« Reply #67 on: Apr 23, 2017, 09:42:35 AM »
And one scuffed up cylinder, although they all appear to be in pretty similar condition
  • Turtle Points: -9
  • Male Posts: 67
« Reply #68 on: Apr 23, 2017, 07:09:00 PM »
So this is about how cylinders 2 and 3 measured (side to side), 3.6265" although I calibrated the bore gauge with a set of calipers (Mitutoyo) so not quite as accurate as if I had set it with micrometers, so almost .027" over. Front to back they were about .024" over. Cylinders 1 and 4 were both about .0245" over side to side and .022" front to back. So, I think I'll probably end up boring .040" over to be safe
  • Turtle Points: -9
  • Male Posts: 67
« Reply #69 on: Apr 24, 2017, 12:03:22 AM »
Wait, I might not have to go that much over bore, just read elsewhere on the interwebs that a 22re std bore diameter is 3.622", is that right? Because that would only put me .0045" over and I can say the wear in the cylinders looks and especially feels worse than that. Guess I'll have to check the manual and see what it says
  • Turtle Points: -9
  • Male Posts: 67
« Reply #70 on: Apr 30, 2017, 05:56:12 PM »
Nothin left of that guide, was in about 40,000 pieces in the oil pan
fireitup
« Reply #71 on: Apr 30, 2017, 06:18:19 PM »
Stupid plastic chain guides...
Where'd you get your timing chain cover?
 :biggthumpup: :popcorn:
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,225
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #72 on: Apr 30, 2017, 07:09:12 PM »
If I could do my rebuild over, I'd go .060" on the over bore.   :D
The stock bore is 92 mm  or 3.62205 inches.
Gnarls.
Gnarly4X
  • Male Posts: 4,225
« Reply #73 on: Apr 30, 2017, 07:19:12 PM »
I have given high praise to the Toyota engineers who designed the 22s.  BUT...they were drinking way too much sake when they were designing the plastic timing chain guides.
The German engineers who designed the VW bug also built an incredible vehicle..... but they got anxious about wanting to test drive it when they designed the gear shifter..... they were obviously drinking way too much vodka!!
Gnarls.
« Last Edit: May 01, 2017, 04:21:11 AM by Gnarly4X »
  • Turtle Points: -9
  • Male Posts: 67
« Reply #74 on: Apr 30, 2017, 07:39:05 PM »
I found it on Amazon, along with the oil pump, water pump, abbr gasket kit. I think everything else is gonna be ordered from LCE though
  • Turtle Points: -9
  • Male Posts: 67
« Reply #75 on: Apr 30, 2017, 07:44:09 PM »
Okay more pictures!
All but maybe one main bearing was spun (by their conditions by varying amounts of time)...
And all rod bearings were spun!! Do I win some kind of prize yet!?!?
So I think I'll probably end up getting a new crank and new rods, because these are all destroyed beyond repair
Gnarly4X
  • Male Posts: 4,225
« Reply #76 on: May 01, 2017, 04:31:28 AM »
I don’t know the history of this truck, but whenever I see photos of a Toyota engine in this condition, I immediately ask “WHY”?  Why would someone drive a vehicle and NOT do preventative maintenance on it?  Yes, catastrophic component failure does happen, but neglect and stupidity destroys more engines.  I think it’s common knowledge that you have to work really hard to kill a Toyota truck.
Regarding your camshaft choice.  What have you decided?  I’m just curious.
Keep up the good progress.
Gnarls.
  • Turtle Points: -9
  • Male Posts: 67
« Reply #77 on: May 01, 2017, 10:03:44 AM »
Gnarls.
Yeah I don't know any of the history of the engine either, just bought it as a core to rebuild. The guy I got it from said it ran but only well enough to get it on and off a trailer, and he bought the truck for the cab to replace his after it rolled. As for cam selection, I haven't really decided yet. Maybe this week I'll make a spreadsheet comparing the stock cam to some of my other choices, and I still need to look a little more into cam theory to better understand what all of the lift/duration/overlap numbers mean
Gnarly4X
  • Male Posts: 4,225
« Reply #78 on: May 01, 2017, 06:28:32 PM »
Hey sassparilla_kid,
I should have clarified... I did not mean to imply in any way that YOU were the bad-boy!
I'll be VERY interested in the information you post on anything on camshafts!
Gnarls.
  • Turtle Points: -9
  • Male Posts: 67
« Reply #79 on: Jul 11, 2017, 06:26:22 PM »
Been lagging on this, hopefully I can get back to it next month. Been too busy at work, trying to fix up the boat I just picked up,  and also have been paying more attention to my NEW '17 Tacoma  (I started a thread about it in the other forum if anybody is interested)
Gnarly4X
  • Male Posts: 4,225
« Reply #80 on: Jul 12, 2017, 06:15:23 AM »
Been lagging ...... been paying more attention to my NEW '17 Tacoma...
Is it sitting in ramps because you are washing the oil pan??  :rofl2:
Gnarls.  :gap:
« Last Edit: Jul 12, 2017, 02:10:16 PM by Gnarly4X »
  • Turtle Points: -9
  • Male Posts: 67
« Reply #81 on: Jul 12, 2017, 09:49:14 AM »
Haha no I had a bunch of dirt in the bed that turned in to mud when I started washing the truck and pulling it up on ramps was the easiest way to get the bed to drain as I was housing it out
cporche
  • Turtle Points: 306
« Reply #82 on: Jul 12, 2017, 11:37:15 AM »
"Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
Vehicles converted to 100% electric drive, with all power supplied by on-board batteries are considered in compliance with the engine change requirements. All fuel system components must be removed prior to inspection. For additional information contact the ARB helpline at (800) 242-4450"
Gnarls.
Ok i had a thought once tesla model 3's start hitting the roads some will be crashed, one could potentially buy a wrecked model 3 convert a vehicle to electric and skirt all smog checks from that point forward. Perform any engine swap one would want as you would never need a smog again. Sell the model 3 drive train to someone else who also wants to perform a similar swap.
Gnarly4X
  • Male Posts: 4,225
« Reply #83 on: Jul 12, 2017, 02:17:03 PM »
Yeah... I figured you were washing out the bed.  I did the same thing after hauling 1/2 ton of sand in the bed.  I drove the front end up on a 4x4 in my driveway, which has a slant to it.   It made it quicker to hose out the sand. :thumbs:
Gnarls. :gap:
  • Turtle Points: -9
  • Male Posts: 67
« Reply #84 on: Aug 06, 2017, 10:27:06 PM »
I have pistons (hypereutectic, +.020") and forged chromoly connecting rods ordered from LCE, hopefully they come in tomorrow because the block gets to ride around in the back of my truck until I have a chance to take it in to be bored/decked. Fortunately the machine shop is only five minutes from work
  • Turtle Points: -9
  • Male Posts: 67
« Reply #85 on: Aug 16, 2017, 03:34:34 PM »
Block is back from the machine shop, now to wait for some bottom end parts to come in so I can start reassembly. I'd post some more pictures but photobucket doesn't allow it anymore  :-\
  • Turtle Points: -9
  • Male Posts: 67
« Reply #86 on: Oct 01, 2017, 09:33:19 PM »
Okay have all bearings, new pistons (hypereutectic), connecting rods (forged chromoly h beam), and new crank in hand, just ordered a pro torquer cam from lce and adjustable cam gear, maybe next weekend I'll get to start the reassembly process
  • Turtle Points: -9
  • Male Posts: 67
« Reply #87 on: Oct 16, 2017, 09:36:37 AM »
Crank, rods, pistons are in. Next weekend hopefully the head and timing stuff will go on
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #88 on: Oct 16, 2017, 10:44:57 AM »
Photos, pictures, images and pics.
– Steve McQueen
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #89 on: Oct 16, 2017, 11:45:39 AM »
if you have cell phone try tapatalk that's how I am able to post pics
Last post Jun 01, 2005, 10:21:46 PM
by alfio
Last post Dec 13, 2007, 04:08:02 PM
by 84pickup
Last post Jul 09, 2008, 05:13:41 PM
by gotxqss
Last post Aug 31, 2012, 01:47:39 PM
by deans87
Last post May 21, 2016, 04:26:57 PM
by OVRAROK
