Author Topic: New fan and shroud  (Read 6361 times)
fasterspider
  • Turtle Points: -2
  • Male Posts: 278
  • Member since Apr '16
New fan and shroud
« on: Feb 02, 2017, 02:10:41 PM »
When I put the air conditioning system into the truck and turned it on, the engine almost over heated with a quickness so I bought a 3 core V6 brass/copper radiator and fan shroud only to find out the hard way that the fan is not centrally located and that brand new shroud was a wasted purchase.
I put the 4 cylinder shroud back on but, it is too short and did not do a good enough job of funneling the air through the radiator so I put two 7" electric fans in front of the condenser that come on with the air conditioning.
Those two extra fans are staying on the truck and will continue to work with the air conditioning but, the big 16" fan should pull more than a sufficient amount of air through the radiator being it is for 30s model good ol' Ford flat head V8.
Regearing the truck did a lot toward efficiency from 100% better fuel economy to less engine heat. Yes, my mileage actually doubled when I went to 4:88s but, she was only getting 9 mpg and now she gets close to 18 mpg or better.
fasterspider, now older and slower.
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
Re: New fan and shroud
« Reply #1 on: Feb 06, 2017, 12:42:15 PM »
The 22R doesn't leave a lot of options for temperature sender switches if you are actually happy with the original semi idiot gauge like I am because I'm an idiot but, I fit this 36 mm hose adapter to the top hose so my new fan will actually work as designed.
fireitup
  • Turtle Points: 530
  • Member since Feb '17
« Reply #2 on: Feb 21, 2017, 04:02:41 AM »
My 82 Pickup has stock A/C.  After recently doing the timing chain, i decided to not put the fan shroud back in as it was about rusted through.  Might have to get one  though now that I hear you were overheating without it... Haven't been able to run the engine long enough to find out if I need it.
82 Pickup - 22R : OME NitroChargers/Springs : Timing Chain @ 180K
Mudder
  • Turtle Points: 3487
  • Member since May '15
« Reply #3 on: Feb 21, 2017, 08:29:01 AM »
On my 89 I ran without a fan shroud and it had AC and it did fine even with an 8274 in front of the radiator.
fireitup
« Reply #4 on: Feb 21, 2017, 09:45:11 AM »
I'll leave it off for now then as an experiment. Thanks for the feedback Mudder
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
« Reply #5 on: Feb 21, 2017, 11:17:00 AM »
fan shrouds are almost on the same level as the oil debate...some people don't run them, some people say you need them. I run without a shroud and my truck would always overheat while sitting due to a bad thermostat. after the stat replacement, it's yet to overheat with a flex fan and spacer from LCE.
I'd say if you get a good deal on one get it, but i don't notice any difference and I live in 105°F summer arizona
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #6 on: Apr 01, 2017, 09:50:39 PM »
Me buying and installing the electric fan and aluminum shroud was a complete and total waste of time and money, she is back to belt driven can and runs cool enough as is, even on the freeway going up hill on a warm day.
MrFatEggs
  • Member since Apr '17
« Reply #7 on: Apr 07, 2017, 12:20:53 PM »
I don't have a shroud or clutch fan on my stock 22r. I have a cheap $30 eBay electric radiator fan, and I have not overheated. My water temp has not exceeded 210°F.
300k
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #8 on: Apr 07, 2017, 12:57:02 PM »
and you get all that extra powah!!! at least like....half a BHP lol
fireitup
« Reply #9 on: Apr 18, 2017, 08:38:36 AM »
Ran errands all day Saturday with no shroud and it didn't even come close to overheating.  Temps were in the low 80's. I think i'm good...
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #10 on: Apr 24, 2017, 08:34:07 AM »
We deal with 100°+ temperatures on a regular basis and a shroud is pretty much mandatory.
My truck loves temperatures in the 80° range, that is child's play.
Eygon
  • Member since Jun '21
« Reply #11 on: Jun 22, 2021, 06:25:27 AM »
As I understand your air conditioner needs a serious clean. That is a typical case. It could be challenging to do by yourself. I have tried once to clean the cabin filter. The most challenging was to find the filter. Finding the filter, you have to decide if you replace it with a new one or clean it. Depends on your money, man. However, I would highly recommend changing it. The most tricky part is to wipe the fan blades.  Of course, I removed the air conditioning condenser, and I couldn't put it back together. My lesson was to call professionals. It doesn't matter if it costs a little bit expensive. The last time I called https://www.airconservicingsingapore.com/ they have done my three-hour work in half an hour.
« Last Edit: Jun 24, 2021, 01:49:41 AM by Eygon »
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #12 on: Jul 16, 2021, 09:20:01 AM »
I disconnected the AC back then in 2017 and then last year fixed the system again with new lines, new condenser, drier and added a condenser fan.
When I initially installed the AC system, I did thoroughly clean the blower and it had clean filter then too. All of the refrigerant leaked out because the AC shop did not replace the o-rings as they were instructed to do last year. I will be finding another AC shop or buying the equipment and doing the job myself.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #13 on: Jul 16, 2021, 04:28:18 PM »
Don't forget about the compressor shaft seal.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Eygon
« Reply #14 on: Jul 26, 2021, 06:27:26 AM »
Hi man! From what I've read, your problem seems pretty complicated, at least to me. I'm not a handyman: every time I have a problem, I prefer to leave it to the experts. While we are on the subject of air conditioning systems, I think I can suggest a great company specializing in AC installation, repair and maintenance. Check it out at https://www.spartamech.co.uk/. It also has a great team of AC engineers: they can design the air conditioner that best suits your desires and needs. I reckon you could find what you need and that you won't be disappointed. Have a nice day!
« Last Edit: Jul 30, 2021, 01:32:59 AM by Eygon »
Last post Feb 09, 2007, 02:40:38 PM
by Tallchevy
Last post Sep 02, 2007, 03:23:11 PM
by robski
Last post Jan 07, 2011, 09:39:10 PM
by yoshaleng
Last post Jun 03, 2014, 06:55:30 AM
by kllangeland
Last post Oct 30, 2015, 08:27:51 AM
by Erick561
