Author Topic: Working on a Tracker  (Read 2288 times)
Prismo
  • Turtle Points: 8292
  • Member since Oct '03
  • Living in the green house
« on: Jan 22, 2017, 07:46:48 PM »
Trying to get the girlfriends Tracker fixed to sell, way too many cars & trucks here. It had been making a rattling noise in the top end. A friend gave me brand new lifters for 40 bucks so I dug into it. Found only one obvious sign, scratched bore & lifter & a bit of hard carbon caught in the lifter oil ring. Other than that there was normal polishing at the top & bottom edges of the lifters on a 180k engine.  I need to buy a set of bore gauges & check the lifter bores for diameter tomorrow. The scratches are not as bad as they appear in the picture but they are present. I am honestly thinking of smoothing the bore with 1500 grit paper if the bores mic within spec.
Prismo [OP]
Re: Working on a Tracker
« Reply #1 on: Jan 25, 2017, 03:06:12 PM »
OK, I have a computer to post with again. Here are the cams. I used the gauges to measure the bores & double checked my readings with the caliper. Everything is within spec so I am moving forward. I used 1200 grit paper to smooth the scratched bores, cannot feel any scratches now.
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #2 on: Jan 25, 2017, 03:11:19 PM »
Do any of the Valves appear to be lower that the others? Tip of the valve that contacts the lifter.
what kind of sound?
is the sound engine speed?
Or 1/2 of engine speed (indicating valve train noise)?
nothing to see on the cams. no scissor gear on them.
I am 1/5th of Perfect Fit
Prismo [OP]
« Reply #3 on: Jan 25, 2017, 03:25:09 PM »
I tracked it by sound to the top of the engine at the front where I found the scratched lifter bore, it was definitely top end related. No broken valve springs or anything odd looking. You could see where the lifter was catching in the bore & there was a piece of hard carbon in the oil ring around the lifter when I pulled it. Sounded just like a badly adjusted valve in a 22re lol
Prismo [OP]
« Reply #4 on: Sep 06, 2017, 07:39:52 PM »
Well, we sold the Tracker last month.
 Figure I would show you guys the new removable mudflaps I made this week.
Prismo [OP]
« Reply #5 on: Sep 06, 2017, 07:45:18 PM »
And then it was "Hammer Time". I have nicknamed my buddy hammer hands, he over tightens everything. His custom "scoop grind" cam. :shocking:
Last post Mar 29, 2007, 07:52:00 PM
by POWERSTROKEN
Last post Nov 26, 2007, 06:38:39 PM
by jta
Last post Dec 12, 2007, 08:53:06 PM
by skipnrocks
Last post Mar 08, 2008, 10:00:08 PM
by Yota_Gotta_Krawl
Last post Apr 13, 2012, 11:57:52 PM
by toysfreak
