Author Topic: Lets be honest does someone really need a 30 spline birfield?  (Read 6863 times)
TRox
  • Turtle Points: 113
  • Male Posts: 33
  • Member since Dec '16
  • 109:1
    • Buy me a drink
Ill soon be diving into the front axle, im curioud if i really need to spend 800 on a rcv. Running 35s right now e locked on stock shafts will no issues yet. Max might be a 37 later on but need some rock sliders and cage or roll bar next on the list.
94 Toyota 2wd SAS,w59, 23 spline duals, 5.29s, elocked, 35x12.50.
52k miles.
IG: Twindle_
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
No you don't need them. You don't need life insurance either. You'll probably not die.  :screwy:
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Okay, so I'm looking for a proven cheaper alternative
52k miles.
IG: Twindle_
SqWADoosh
  • Male Posts: 2,417
There are a few things not to go cheap on with these trucks. Axle shafts is number one. Bite the bullet and get a RCV. They can be had for $612 here: http://www.jesterfab.com/collections/toyota/products/rcv-300m-chromoly-birfield-axle-set
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Ill willl book mark it and probably end up going with the best. I like the piece of mind, but I also dont beat on my truck and dont bind my stuff up like ive seen. Real quick do door add much cab safty in a roll over situation? I want to get them off in the spring.
52k miles.
IG: Twindle_
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
RCV's are a must have!  :twocents:
SqWADoosh
  • Male Posts: 2,417
Honestly they are pop cans with or without the doors.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Don't skimp on axles. I have og bobbys in all of my rigs. Never broke one. I've killed numerous stock birfs. I would say yes the doors do help a little. But not enough to justify sweating your butt of when it's hot. I prefer tube doors. Also a good option is a small cage or at least a hoop behind the cab.
01 double cab hunting truck
06 tacoma street truck
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Thanks for the reply guys, I kinda wanted to get a in cab cage but not sure yet on that, got some sliders on order right now. Just relized my truck has the pimp lean to passenger side, pad is welded on the drivers side and ended up leaning passenger after settling ha! What bs. Rcv and go ahead and save and get the hub set to? All these little things that keep happening. Something is always acting up. But its all worth it when you get to the trail!
52k miles.
IG: Twindle_
SqWADoosh
  • Male Posts: 2,417
Welcome to the sickness  :ha_ha:
79chevy39.5s
  • Turtle Points: 197
I run trailgear longfields. I got them on closeout pricing before the gun drilled came out i build on a budget so i chose what i could. My first gen has 27 spline longs in it.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
IMHO my answer is yes you need them. Considering the first Birfield I blew was a low speed backing up in camp on flat ground. It screwed up the ball and took the splines off the stock shaft. Worth the money, yep!! :gap:
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Thanks for the input guys, I debated selling my truck but then realized I would regret that for the rest of my life. I got rock sliders in the garage needing paint and welded on, any cage ideas? I thought about an exo off the sliders and down to the stinger In hope that it would save the pillars in a roll over. Next on the list is front shafts and cage and its closer to being done. I was thinking of going with a tube camper with a canvas top. Any recommendations on the interior? Carpet or bed line?
52k miles.
IG: Twindle_
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
Gotrocks had chromoly upgraded front axles on his first gen 4Runner on 37s and he broke them both plus one of the stock replacements in two days in Moab. He wasn't easy on it, but wasn't abusing it either. He had the original Longfields overnighted (currently RCV is the equivalent) and saved the trip. He tried to save some cash with the chromoly shafts and it didn't work out for him at all. I have successfully run 33s with a Trutrac limited slip in the front of my 85 truck with success but did original Longfields when I did the Aussie Locker and 35s.
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Ordered some RCV's last night with other fun stuff.
52k miles.
IG: Twindle_
TRox [OP]
  • Male Posts: 33
  • 109:1
    • Buy me a drink
Arp knuckle studs and hub studs, hopefully these axles are shimmed correctly and it will be a breeze. Im gonna do the camo method seemed to be the best way.
52k miles.
IG: Twindle_
Mudder
  • Turtle Points: 3487
If you haven't gotten into the front axle before I'd recommend tearing it all down to get a good look at every part
SqWADoosh
  • Male Posts: 2,417
Absolutely agree with Mudder.
knapp870
  • Turtle Points: 2
  • Member since Oct '17
I have gun drilled 30 spline in my rig on 37 stickies behind an LS and Atlas and so far hold up great other than stripping splines once
Last post Jul 28, 2009, 12:22:10 PM
by Emerz
Last post Mar 10, 2010, 07:13:14 PM
by sweetmeat
Last post Jan 16, 2013, 05:34:38 PM
by tyes
Last post Sep 14, 2014, 08:43:24 PM
by Stlstrs
Last post Oct 14, 2015, 09:28:37 PM
by Twiztedaxles
