4WU 3Link Bracket Kit:
LASER CUT, 1/4" plate, none binding design, 2 position link adjustment, zero bump steer, Relocates axle 1.5"- 4.5" forward. Includes 2.0" air bump cans, axle side shock tabs, bump can gussets, anti sway bar tabs, steering stop reinforcement. Plus frame reinforcement kit will come with this kit.
**Brackets on axle is for stock front FZJ80 axle** Check the link for more info:
http://www.4wheelunderground.com/3-Link-ToyotaAxleSystems.html
4WU 4Link Bracket Kit:
LASER CUT 1/4" plate steel, none binding design, 4 position link adjustment, variable mounting width for upper links, lower link mounting width 2.625" x 5/8", upper link mounting width varies for the user. Use up to a 2.625" at the frame and axle, depending on axle., built in bump pads, frame side brackets includes a MASSIVE 25" backing plate.
**Brackets on axle is for stock rear FZJ80 axle**Check the link for more info:
http://www.4wheelunderground.com/4-Link-ToyotaAxleSystems.htmlBoth kits are brackets only and located in Livermore, California. Spent nearly $1900 for them and changed priorities due to health.
SOLD!
