Author Topic: ABS senc  (Read 2184 times)
hrjay45
  • Member since Jan '17
ABS senc
« on: Jan 05, 2017, 04:02:25 PM »
any one know where I can buy a blockoff plate for the rear abs sensor in the third member of a toyota 8in v6 dif.
have seen one that fits the sensor hole and has a hole for a cap screw that holds it in place.
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
Re: ABS senc
« Reply #1 on: Jan 05, 2017, 04:13:48 PM »
I used a freeze plug 3/4"
immi.jfreeman
  • Member since Aug '15
Re: ABS senc
« Reply #2 on: Jan 05, 2017, 04:41:14 PM »
I 2nd that. Works perfectly.
Sent from my XT1585 using Tapatalk
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
Re: ABS senc
« Reply #3 on: Jan 05, 2017, 05:50:34 PM »
10-4 on the freeze plug, clean your hole with some alcohol and add some red RTV and you're done.   :burnout:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
knapp870
  • Turtle Points: 2
  • Member since Oct '17
Re: ABS senc
« Reply #4 on: Nov 28, 2017, 07:13:40 AM »
Freeze plug but I was in a pinch once and used JB weld. Worked awesome  :driving:
gnob
  • Turtle Points: 486
Re: ABS senc
« Reply #5 on: Nov 28, 2017, 07:27:05 AM »
Just cut the wire and leave the sensor.
hold this. . .
joeyf
  • Turtle Points: 848
  • Member since Dec '06
Re: ABS senc
« Reply #6 on: Nov 28, 2017, 09:24:29 AM »
X2
If you still have the sensor this is the easiest thing to do.
Ritchie
  • Turtle Points: 539
  • Male Posts: 265
  • Member since May '13
  • Ritchie
Re: ABS senc
« Reply #7 on: Nov 29, 2017, 04:04:18 PM »
Do this mod:  https://www.tacomaworld.com/threads/abs-delete-2001-2004-tacoma.377243/
I did this after my SAS and rear Diamond install.
Be sure to pull the ABS fuse from the fuse box under the hood along with the bulb in the dash (PITA).
Go with a Wilwood (or comparable) proportion valve.
You will like the way it stops... mine stops on a friggin' dime.
Good luck.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
