Author Topic: Broken Lock Right locker  (Read 6492 times)
fasterspider
  • Turtle Points: -2
  • Male Posts: 278
  • Member since Apr '16
« on: Dec 27, 2016, 02:15:47 PM »
Ive spent the past week putting high steer and new shock towers in the front only to take her out and find the rear auto locker decided the torture I had been dishing out was enough and she was one legging it in the snow and ice of my buddy's driveway up in the mountains of Los Angeles.
I'm having one 3rd member welded and putting another limited slip differential up front.
The most important of these mods is the re gear from 4:10 to 4:88 so my rig will make it up a hill on the freeway without shifting down into 3rd because of the 33" BFGs.
fasterspider, now older and slower.
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
Re: Broken Lock Right locker
« Reply #1 on: Dec 28, 2016, 07:12:10 AM »
I had the same experience with the lockright. I broke it shortly after putting the truck on the road. I run 35's and Mine was in the rear diff.
I decided to go with a Spartan to replace it. I also used a v6 carrier 4 pinion and installed it into my 4cyl 3rd member using the conversion side bearings that Arb uses. I would not recommend the lockright (weak old design) but I would also not recommend the Spartan (extremely aggressive, Loud pops when it disengages, Sounds like a broken axle every time). I think a Detroit is the ideal option, or an air locker. I ran the welded rear diff in a previous vehicle. Bad Idea, wore the tires down so fast. Maybe if its offroad only.
I am 1/5th of Perfect Fit
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #2 on: Dec 28, 2016, 08:28:41 AM »
If you don't mind how the Lock-Right functioned when it worked I would  suggest the Aussie Locker as a replacement.
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #3 on: Dec 28, 2016, 10:58:32 AM »
Eventually I'll be going with air or E lockers but, for now the welded rear has to suffice.
I hated the way that POS Lock Right sounded, especially for the last month so I'll be using a limited slip locker up front like I've had all year.
When money allows, I'll buy new lockers but, I have the posi traction under control for 2017 and now that she is getting re geared, she's going to need axles and burfields and they are going to be the next major purchase.
It's funny how money dictates all, I don't like dictators.
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #4 on: Jan 02, 2017, 04:43:58 PM »
The re gearing was working well until the transmission blew up on the freeway and forward motion ceased and waiting on AAA began.
The transmission failing made me miss out on an awesome trail ride that lasted all day for them, lucky bastards while it took 3 hours to get from Gorman up to Frazier Park & back down to the San Fernando Valley.
toysfreak
  • Turtle Points: 227
  • Male Posts: 632
  • Member since Sep '03
  • I Love My Marlin Crawler!
« Reply #5 on: Jan 13, 2017, 10:53:02 PM »
Update this :pokinit: Ray
95 4 runner. 4 cyl dual ultimate w. R150.  V6 rear w spool.  New Chevy springs on 12" extended frame.      Front.  SAS w chromoly shafts.  And spartan    In frazier park ca 93225
fasterspider [OP]
  • Turtle Points: -2
  • Male Posts: 278
« Reply #6 on: Jan 15, 2017, 03:45:20 PM »
The transmission and transfer cases are and we're still as good as new, so was the clutch but, the newly rebuilt rear 3rd member came apart and ate up my brand new 4:88 ring gear.
It looked to me like the rebuilder forgot to use thread locker and the two large bolts backed out which allowed the whole side to unscrew then come away from the pinion gear enough to lose forward motion.
The next time something fails, I not saying anything until it is fixed.
It felt so catastrophically bad when it failed I assumed it was the transmission but, I learned a long time ago that when you assume you make an ass of u and me but, again I'm the only ass. My being a catastrophist gets me in to more dumb stuff than I can comfortably admit to but, there it is there.
toysfreak
  • Male Posts: 632
« Reply #7 on: Jan 15, 2017, 08:07:24 PM »
Was a 1st to me too.   Have never seen that happen b4.
Your a die hard kinda guy,   you will fix it.   Get ya back up and going.
Wonder if anyone else can chime in,   if they have ever seen this,  or experienced what had happened??
Assumed it was the trans,  so came to help you remove it,  figured out it was the diff,  assumed it must be dat too.   Was a heck of a time gettn it out of the housing.   Not assuming anymore,  just hoping to hear back from ya,   put you in touch with the builder,  haven't heard from ya since
Been texting you,  but come to find out,  was your home # again.   Lol
BlueRAY  works great.   Danks again Buddy
:)bestgen4runner
  • Male Posts: 1,796
« Reply #8 on: Jan 15, 2017, 08:23:00 PM »
I have done many of these with no issues and never used lock tight on the bolts that came loose. Always just torqued to spec. Maybe I will start? Some body ask zuk if he does, I am curious.
Willard
  • Turtle Points: 1608
  • Male Posts: 627
  • Member since Dec '14
« Reply #9 on: Jan 15, 2017, 08:43:13 PM »
I have always used lock tight on diffs I build. I have seen this same situation occur due to no lock tight being applied to the cap bolts. Mostly see failures on the ring gear bolts coming loose when no lock tight was used. On a second note, how long did it take for this to happen?
toysfreak
  • Male Posts: 632
« Reply #10 on: Jan 16, 2017, 10:26:01 AM »
A week
Willard
  • Male Posts: 627
« Reply #11 on: Jan 16, 2017, 10:59:44 AM »
If it happened in a week he didn't even tighten down the bolts.....just my opinion.
:)bestgen4runner
  • Male Posts: 1,796
« Reply #12 on: Jan 16, 2017, 12:01:32 PM »
Or at least did not torque them....
Willard
  • Male Posts: 627
« Reply #13 on: Jan 16, 2017, 02:28:00 PM »
Agreed
toysfreak
  • Male Posts: 632
« Reply #14 on: Jan 16, 2017, 06:40:15 PM »
Quality guy,  gonna warranty it.   Good friends,  good times :beer:
Last post Oct 29, 2009, 01:32:12 PM
by RCKSQRL
Last post Apr 13, 2006, 10:26:29 AM
by eric hohlfelder
Last post Jan 09, 2010, 10:07:38 AM
by Hottrod81
Last post Oct 30, 2011, 06:36:53 PM
by Rockdiver
Last post Feb 16, 2017, 08:24:39 PM
by blackdiamond
