I was thinking the truck was a really faded red that looked pink................
... I would probably be better off loosing mass running a single row timing chain but I just love the beef of the dual row chain, so I'm going to stay with that.
On dual timing chain.... why do you "love the beef" of the dual chains instead of a single timing chain?Gnarls.
Having had a few combos of them in the same truck, I can honestly say I couldn't see doing any of this on anything but a hybrid. Absolutely best combo I'vd had, and it was equally quick in the 1980 4x with the 20r head and open exhaust as it was in the 81 2wd with stock exhaust, even with around 370k miles on it.I still have that block and plan to have the bottom end bearings fixed (not paying the dude down the street the "buddy deal" of $1,000 he quoted me to re-size bottom end bearings!), hone it and swap on a good 20r head to see how much more abuse it can take before something else gives.
I wonder what's cheaper, punching the 20r block out to fit 22r pistons or line honing the mains on the 22r block? We will see.
Well see now, that's basically what I have and it's the 2nd most gutless combo I've had, worst being the stock 20r. I have a 20r block that's bored .60 over that ATK passed off as a 22r according to po, which I sorta believe since it's ground smooth where it usually is stamped 20r or 22r.There's a wrecked 2wd 81 locally for $600 that I'm tempted to go see. If that engine is as stout as my old 81 22r, it'd be worth it for me to try talking him down a little
Oh it gets worse... Visited with Tim at DOA. .. He also says boring out the 20r block to .040 oversized 22r size should be cheaper than line honing the 22r block.
.. Visited with Tim at DOA. I ran his C270 years ago in a 22re and loved it...... his new .443 lift split duration version of the C270...
Did you happen to get the specs on this cam?Thanks,Gnarls.
Are we talking about line "honing" or line boring?Gnarls
Well I don't know but they make the cylinder the 22r size for the 22r pistons. 3 mm seems like a lot to "hone". I don't know what they call it.Maybe you are asking about the main bearing journals on the block? That is what I needed to fix on the 22r block that was about $160. I guess that is line "bored" since they cut down the bearing caps and cut a new hole. Anyway I don't know the lingo but I know what it is and what it costs me .
The notion that with the hybrid you may be stuck running premium may kill it for me though. I really dig how my 20r runs on garbage and I'd like to keep that.
Never had to run more than 87 octane in my hybrids, and until CA changed their gas, it'd run old gas without a hickup. I have to run 89 or 91 octane in my stock 91 22re unless I wanna hear it ping under even the slightest load. I can get away with 87 if only running around town, but if the possibility of a road trip with freeway driving or hills (hell, even if it's windy) is on the horizon, I'd better use higher grade.
Started by rick80 Parts For Sale
Started by weirdtimes_7 « 1 2 » Chit Chat Camp
Started by the_white_shadow Parts For Sale
Started by SKULLYOTA Transfer Case/Drive Line
Started by H8PVMNT Engine
