Apr 25, 2024, 02:19:31 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Project Research and Build-Ups
(Moderators:
Willy Mammoth
Blingn
Topic:
Congill77 87t4r go anywhere dd build
Pages:
1
2
3
4
5
Go Down
Print
Author
Topic: Congill77 87t4r go anywhere dd build (Read 31017 times)
H8PVMNT
Silver Turtle Award
Turtle Points: 452
Member since May '07
I'LL NEVER MAKE IT...
Re: Congill77 87t4r go anywhere dd build
Reply #120
on:
Feb 14, 2018, 09:45:29 AM »
Not really. Solid axle has thinner solid rotors and smaller drums. You can use FJ60 rotors on a solid axle with IFS calipers though.
Logged
– Steve McQueen
"Except for maybe Seattle." -H8PVMNT
"I plan to hit 300k in this truck" :)bestgen4runner
"I'm jealous of your shop. It has concrete and doesn't smell like pickles like the old shop " 300K
Congill77
[OP]
Rock Master
Turtle Points: 2
Member since Nov '16
Crawling with Marlin
Reply #121
on:
Feb 14, 2018, 07:50:49 PM »
That’s h8, I plan on putting the 97 housing that I have in the new ones as for the front, I have no clue what I have.
Though, I asked about the E brake...... but I did some direct comparison and yes the E brake mounts are the same.... but they have been cut off the sa one....
I’ll be looking at the t case e brake now.
On another note, how relevant is the charcoal canister to a non emissions vehicle?
Logged
Mudder
Crawler Guru
Turtle Points: 3487
Member since May '15
Reply #122
on:
Feb 14, 2018, 08:01:50 PM »
Keep the canister. It helps keep the fuel smell down
Logged
300k
and
H8PVMNT
like this
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #123
on:
Feb 15, 2018, 06:34:49 AM »
Ok cool. I’ll hold on to it.
Logged
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #124
on:
Feb 26, 2018, 04:07:40 PM »
Soon.... very soon
Logged
likes this
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #125
on:
Mar 19, 2018, 06:46:05 AM »
Ok dumb question, what is pressure that the stock power steering pump/ ifs steering box runs at?
I ask because i am buying a 4wheel steer kit off a buddy for cheep, but I’m not sure if I want to run full hydro in the front because it’s illegal to run on the street.
So I’d like to just run Hydro assist in the front but also run rear steer. Is it possible to run a psc pump to the stock steering box?
Logged
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #126
on:
Apr 13, 2018, 06:42:40 PM »
Logged
rybike
:)bestgen4runner
and
OVRAROK
like this
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #127
on:
Apr 30, 2018, 06:33:37 PM »
Ok, got the motor running. (It’s only been in for months now) I have the transmission and both tcases in, need to figure out to mount the new rear crossmember to the frame. I have the front axle in with 5 in lift pro comp (I think, bought secondhand) psc double ram on, ps lines run, cooler mounted, 39.5s on the front on, still have 35s in the rear currently due to the fact that I need to trim a lot of the body. Also have an aal for the Chevy 63 in the bed of my tundra, should give me a little more clearance as well as hopefully stopping the rears from rainbowing as it flexes. I got it garage flexing this past weekend (insert pictures here):
and that last picture is why some of the body is going away, again, that’s only a warn out 35, not the 39.5 that will go on it. Also probably gonna have to take a bfh to the front to clear the tires at full stuff. Waiting on orbital valve mounting kit and their direct fit valve neck. As well as a front axle rebuild kit from marlin so I can install the front range off road keyed steering knuckles and arp studs. Then comes drive shafts..... so my transmission is going to have to be tilted down just slightly so that my ebrake doesn’t hit the body/fuel line that runs right there. That said, the lift on both the axles completely throws off the pinion angles.... bad. So once I get the aals installed on the rear, I’ll go through and order shims and what not to get it all sitting nice. Enjoy some more pictures
Logged
rybike
likes this
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #128
on:
May 21, 2018, 09:12:26 PM »
Logged
FRANKENYOTA91
and
300k
like this
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #129
on:
Jun 18, 2018, 02:53:53 PM »
Have 2 elocker diffs with a master tech friend and he’s setting them up for 5.29s
Logged
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #130
on:
Jun 18, 2018, 02:56:24 PM »
I’ve also come across a deal on some slightly used og bobby longfield axles for a decent price no clue what any of the Axles in my existing axles are, but I’m excited to have a set of bobby longs
Logged
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #131
on:
Jun 18, 2018, 03:00:21 PM »
Also, does anyone have their gas tank relocated to where the rear seats used to be?
Logged
Congill77
[OP]
Rock Master
Turtle Points: 2
Reply #132
on:
Sep 17, 2018, 11:30:11 AM »
https://m.youtube.com/watch?v=_of9wBj9VVM
Logged
rybike
likes this
Pages:
1
2
3
4
5
Go Up
Print
(Moderators:
Willy Mammoth
Blingn
Topic:
