Author Topic: Holy Lord I need some help....  (Read 4296 times)
FatAzzRunner
  • Turtle Points: -191
  • Male Posts: 448
  • Member since Jul '02
  • Kansas, Flexin on cowpatties
« on: Sep 10, 2016, 11:13:56 AM »
I've tried searching as to keep from bugging you guys but I have reached my last nerve.
We think my sons Clutch is out and we don't want to fully pull the tranny to figure out what we have just to be able to order parts.  I have been all over this site on the rebuilt transmission page and can't figure out what this is.     Problem is this truck has turned out to be a cobbled together mess from the PO and we're not sure what's what.
The truck used to have a 22RE in it with a W56 based off the door jam plate.  Now it has a 3.4 (not sure what year or from what) and I have zero idea what tranny he used.  It looks kind of like a R150 or 151 but then there are differences that make me believe otherwise.
On top of not knowing what trans, this is, I don't know which clutch and flywheel to order.  I'm not sure that the PO even did this right to begin with....  :smack:  :wall:  :help:
I guess my question is this, Can anyone tell, by the pictures, what trans this is?  Am I going to have to pull the trans just to figure this out?  The reason I don't want to pull it yet is because I can still move it around in the drive if need be.
« Last Edit: Sep 10, 2016, 11:31:04 AM by FatAzzRunner »
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
Mudder
  • Turtle Points: 3487
  • Member since May '15
Re: Holy Lord I need some help....
« Reply #1 on: Sep 10, 2016, 12:08:06 PM »
Unless the PO had some badass fab skills the only two transmission it could be would be a R151 or an R150 from a 3.0/3.4. Can you get us some picture of the tail end of the transfer case? SO we can see how many bolts it has and then you can figure out what transmission it is. Go here https://www.marlincrawler.com/transfer-case/line-ups/pickup-4runner-kits ad click on transfercase bible up near thw top, then scroll down and it'll tell you how to ID it. WHich will tell you if it's a gear driven or not. If it's not then you have an R150 transmission.
FatAzzRunner [OP]
  • Male Posts: 448
« Reply #2 on: Sep 10, 2016, 01:38:15 PM »
Looks different than the 7 bolt posted on that Marlin link (Thanks for that by the way) so I'm guessing it's the weaker chain driven........
Mudder
« Reply #3 on: Sep 10, 2016, 02:10:06 PM »
That does look like a chain driven T-case.
FatAzzRunner [OP]
  • Male Posts: 448
« Reply #4 on: Sep 10, 2016, 02:17:32 PM »
So, just to be clear, because of the 5 bolt, I have an R150 trans?
Also, I read that it's best to put a 3.4 fly wheel in, you know if that's correct?
I'm assuming I should order a 3.4 clutch too?
Thanks for the help.
Mudder
« Reply #5 on: Sep 10, 2016, 02:39:17 PM »
There's only 3 transmissions that can bolt directly up to a 3.4, and the r151F is a gear driven T-case, and the R150F is a chain. That's how we can tell it's an R150F. As for the clutch you can run either 3.4 or 3.0 stuff from what I've read and been told.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
« Reply #6 on: Sep 10, 2016, 05:46:56 PM »
that looks to me exactly like a w59 tacoma trans and case
i have one on the floor in my shop
but- the clutch disc is/should be the same between all w/r/g series trannies
Mudder
« Reply #7 on: Sep 10, 2016, 05:56:15 PM »
W59 would be for a 4 cylinder correct?
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #8 on: Sep 10, 2016, 06:10:20 PM »
my guess is r150.  Slave is on the driver side which is how the tacoma is if i remember correctly.  Being Passenger side drop tcase, I assume they swapped bell housings onto an older r150.  :dunno:
Dingman.
  • Male Posts: 3,448
« Reply #9 on: Sep 10, 2016, 06:11:05 PM »
When i did my 3.4 Swap.  I used my 1990 r150 transmission/bellhousing and used the 3.0L flywheel and clutch kit.  Being that he swapped bellhousings i wonder if he used all tacoma clutch components.
Mudder
« Reply #10 on: Sep 10, 2016, 06:15:57 PM »
SOmeone else can confirm, but I do believe that is an older R150F based on the fact that the speedo cable is there.
jackedyotaaaa
  • Male Posts: 7
  • Member since Mar '05
  • FLEX IT!
« Reply #11 on: Sep 13, 2016, 01:10:00 PM »
I'd do some digging in the Toyota bible on pirate 4x4. Any questions I ever had in found looking there.
Sent from my SM-G920V using Tapatalk
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #12 on: Sep 13, 2016, 04:09:03 PM »
looks to be an R150F with a standard chain drive transfer case.
FatAzzRunner [OP]
  • Male Posts: 448
« Reply #13 on: Sep 16, 2016, 09:10:46 AM »
I called MC and they told me that I would have to pull it and send a bunch of pics to their email so they can better tell what it is and tell me what parts to order.
I'm now hearing the motor came from an 01 Tacoma.  Still have no clue on the trans.
I didn't want to pull it until I had the parts to do the rebuild because, right now, we can still move it a little if need be.  Once it's pulled, that's where she sits.
« Last Edit: Sep 23, 2016, 07:02:48 PM by FatAzzRunner »
Last post Oct 06, 2003, 05:07:30 PM
by 79coyotefrg
Last post Feb 15, 2005, 04:58:20 PM
by guywithuglyyota
Last post Sep 24, 2005, 08:04:12 AM
by crawlerdan
Last post Aug 13, 2007, 02:01:58 PM
by abnormaltoy
Last post Jul 08, 2008, 03:02:13 PM
by jimbo74
