Ive done four engines with this and it gets the job done. Its a must if your installing the engine and transmission as a unit. Not sure if its what your after or not http://www.harborfreight.com/3-4-quarter-ton-capacity-heavy-duty-load-leveler-67441.html
Gnarly4x, just took my truck for a spin with the 261C cam and it rocks! I was able to get up to 70 MPH in less than 2 miles while keeping my shifts under 4k. It has more pull over the stock cam. The true test will be after the 500 mile break in and I can go over 4k.
Have fun with that! You'll enjoy being able to accelerate from 45-70 in 5th gear with a moderate pace 💪Sent from my LG-H830 using Tapatalk
Engnbldr'ds stock replacement head and stock exhaustamigold for me sadly.
..... I'm planning on replacing plugs, cleaning my filter, and resetting my timing before going to a dyno for $30 and getting an actual dyno chart.. Anyone wanna donate to the cause? HahaSent from my LG-H830 using Tapatalk
I can do 30 in 2nd too if i want to.. I'm just saying that in 3rd it's really lugging.. and I'm still pulling when i go up that hillSent from my LG-H830 using Tapatalk
.. Now, I've got a bit more done to my motor than just a 261c.....
excabswap,Yeah... she's purrddyyy!! Is that a Doug Thorley header?OK, so I"m also .020" over bore with an engnbldr RV head with OS valves and 261C cam. Block deck cleaned up at .006" smoothed. Crank, rods, flywheel, and pressure plate have been balanced. It's got the stock flywheel and I don't know whose clutch and pressure plate I have and I'm still debating to replace it.Tires for your chassis dyno?..... What is your ring and pinion ratio and tranny model? What tire sizes are you running mostly?The tire size will affect the final drive gear ratio, so it depends on where in your RPM range you want to have your peak torque measured.Oh, so your shop charges $30 for each pull, with a minimum of 2 pulls??I think 2 pulls is a little shy of the norm. My speed shop here does 5 pulls for $99.I'm planning on having my truck on the dyno soon as I think it's broken in well and still freshly tuned.Gnarls.
Started by alfio Parts For Sale
Started by dune_it86 Engine
Started by richard head Toyota Pickup/4Runner Tech 1979-95
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by 83yota Project Research and Build-Ups
