Author Topic: Not your average restoration, 1982 SR5  (Read 34909 times)
joe510
  • Member since Sep '11
« on: May 24, 2016, 11:47:59 PM »
Hey guys, I was lucky enough to come across a heavily optioned 82 SR5 with a factory sunroof. I found it about 40 miles from my place and the lady that was selling it needed money to pay rent. It didn't run and needed a handful of TLC. I bought it with the intention of getting it running and then wheeling it hard. I dropped in a little money upfront and got it running well enough to try to get it smogged. No Bueno...... spent a little more money and got it to where it would pass smog so i could get it put in my name and that's where it stopped for about 4 years. I just couldn't figure out what to do with it... also ran out of money. Should i do a swap to an EFI motor, Exo cage, flat bed? so many options but where to start???
Here it is the day I brought it home. :beerchug:
I made the decision that if I was going wheeling, It would need an EFI motor at best. I met a guy on CL that sold me an SDS EFI system from his truggy and i started tinkering with it.. I could never get it to work right so I just started looking for a 22RE.
Again truck was just sitting and sitting... :dunno: :sleepy:
Lots more photos to come soon.
joe510 [OP]
Re: Not your average restoration, 1982 SR5
« Reply #1 on: May 25, 2016, 12:09:42 AM »
Just a few more pictures taken last summer just before the tear-down.
Somewhere along the lines my brother took the bumpers off and fabbed up some tube style bumpers for the front and rear. Not really to my liking but were going to change that when I put it back together.
[/URL]
[/img]
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #2 on: May 25, 2016, 11:58:15 AM »
I think you need to sell me the tailgate please.  :beerchug:
01 double cab hunting truck
06 tacoma street truck
joe510 [OP]
« Reply #3 on: May 31, 2016, 10:09:29 PM »
So all of the pictures that I have posted so far were of the truck before the tear down. This next group of pictures is going to be of the tear down and then the start of the body work. This next set should take us into current date.
After reading lots of build threads and checking out all kinds of goodies. I make some decisions based on a couple things. the initial solution was to rip out the old motor and drop in the 22RE.
Those plans changed when I realized the amount of HP and torque was not really a great improvement over what was already under the hood. I then started looking at the 2RZ/3RZ setup and after much consideration and research, I decided to go with the 2RZ simply for the fact that its about $700 less and its only about 10-20- hp less than a 3RZ. I figured I could get a few bolt-ons and get the HP back.
I found a decent motor and picked it up along with a set of front and rear Toyota electric lockers and a W56 HD trans. The next items to round up are a marlin dual case adapter and a set of gears for the 3rd members.
Since I never really gave detailed specs of what is actually going back into the truck, now is a good time.
Running gear is going to be a rebuilt 2RZ motor mated to a W56 HD transmission, Custom drive lines down to front and rear factory e-lockers. The rear end is going to be built with chromoly axle shafts and the front is going to get completely rebuilt with some type of chromoly birfields and new disc brakes. As far as the motor goes, I have a few tasteful mods to be done to it but nothing spectacular in terms of horsepower. My ultimate goal for the truck is to build a show truck and then make it a daily driver. It does need to be capable of trails and snow. I do a lot of fishing and camping so it needs to go where i need it to go.
Here are a few more pictures of the tear down process.
joe510 [OP]
« Reply #4 on: Jun 01, 2016, 12:04:02 AM »
joe510 [OP]
« Reply #5 on: Jun 01, 2016, 12:08:51 AM »
Here are a few more shots of the tear down process.
By the way, I'd like to add that I have some amazing friends that have given me a ton of help all along the way for this build.
joe510 [OP]
« Reply #6 on: Jun 01, 2016, 12:10:07 AM »
Got some new shoes for the truck as well.
joe510 [OP]
« Reply #7 on: Jun 01, 2016, 12:14:30 AM »
 Cleaning out all the old tar mat stuff in the cab. Getting ready to repair some rust spots.
The rust really wasn't that bad, however there were spots that needed to be addressed. The passenger side floorboard had a few little Flintstone holes so that will be addressed.
Next up was the frame. I decided to run with the All Pro Offroad 5" solid axle swap kit because it included everything I needed to install the new springs and included the front spring hanger. In addition, it came with all the necessary brackets and bushings along with the Hy-steer and the shock towers for the front.
Here are just a few pics of the frame being worked.
joe510 [OP]
« Reply #8 on: Jun 01, 2016, 12:26:18 AM »
lots of cutting, grinding, and welding going on in these pictures.
[/URL]
[/img]
joe510 [OP]
« Reply #9 on: Jun 01, 2016, 12:29:35 AM »
[/URL]
[/img]
joe510 [OP]
« Reply #10 on: Jun 01, 2016, 12:31:47 AM »
Clearing room for the e-lockers front and rear.
[/URL]
[/img]
joe510 [OP]
« Reply #11 on: Jun 01, 2016, 01:11:05 AM »
Finally got some bodywork done.
[/URL]
[/img]
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
  • What is this Toyota you speak of?
    • Buy me some coffee
« Reply #12 on: Jun 01, 2016, 03:04:30 AM »
Gonna be sweet, lots of attention to detail, i like it!
Refusing to fit in or comply.
Easy is not worth anything.
mudmaster
  • Turtle Points: 3678
  • Male Posts: 2,845
  • Member since Feb '05
« Reply #13 on: Jun 01, 2016, 05:45:57 AM »
This will be nice when you're done  :thumbs:
Time to go wheelin!
joe510 [OP]
« Reply #14 on: Jun 01, 2016, 07:46:58 AM »
There is going to be a lot of attention to detail.  every single nut and bolt has been taken apart, cleaned, and re plated or will be painted to match the body.  I have even started buying OEM parts online from toyota dealers across the US just to ensure i get the right fit and the part is a factory part.
a little nuts....   I think so!!
LittleSteve
  • Male Posts: 943
« Reply #15 on: Jun 01, 2016, 03:16:53 PM »
Seems normal to me
  • Turtle Points: 1051
  • Male Posts: 9,755
  • Member since Oct '04
« Reply #16 on: Jun 02, 2016, 11:41:03 PM »
What parts are you buying online?  I know there's a toyota dealer in oregon who has a lot of little parts for these and sells them on ebay.  I've purchased several oem items from them for my 1980.
toyyota
  • Turtle Points: 5
  • Member since Apr '08
« Reply #17 on: Jun 03, 2016, 03:15:59 PM »
Nice work! I went through a similar frame off restoration on my 83. Last summer I rolled it 3.25 times down a hill, not many body parts left. I do have a lot of original hard to find bits, that I would sell for a worthy project, like yours. PM me if you can't find something. Bob
joe510 [OP]
« Reply #18 on: Jun 16, 2016, 12:25:27 AM »
I think it's Griffith motors, or something like that.  I have been buying little bits and pieces here and there but nothing major.  Interior parts are hard to come by especially the sunroof stuff since there were not many factory builds with sunroofs.  At least so I am told....
  • Male Posts: 9,755
« Reply #19 on: Jun 16, 2016, 12:32:24 AM »
Yup, that's the one.  I've picked up several interior pieces and all but 1 outside marker/corner light from them.  Only thing I wouldn't buy is the dome light lense.  I bought 2 new and neither is built to correctly click into my oe rearview.  No biggie, they rob lots of light anyway, but it is a little annoying to have no lense on it now that the old one dried up and fell off in bits
joe510 [OP]
« Reply #20 on: Jun 16, 2016, 12:35:32 AM »
Finally got some color!!!!   :beer: :beer: :yikes: :yikes:
[/URL]
[/img]
[/URL]
[/img]
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
« Reply #21 on: Jun 16, 2016, 01:18:48 AM »
Smokin' color, can't wait to see the rest of your work   :biggthumpup:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
Plainview
  • Turtle Points: 175
  • Member since May '14
« Reply #22 on: Jun 16, 2016, 06:46:51 PM »
Nice '65 GTO, is that yours too?
I like the color - this is going to be a sweet truck!
'84 Xtra Cab Project:
http://board.marlincrawler.com/index.php?topic=100651.new#new
Parts Wanted:
- Un-cracked dash pad (do they exist?)
joe510 [OP]
« Reply #23 on: Jun 17, 2016, 12:16:35 AM »
Thank you!
joe510 [OP]
« Reply #24 on: Jun 17, 2016, 12:18:05 AM »
No sir.  My truck body is at a buddies shop.  He does a lot of classics.  His main business is Insurance work.
Thanks for the compliments.
  • Male Posts: 9,755
« Reply #25 on: Jun 17, 2016, 12:58:46 AM »
Lookin good!  I may have missed it, but what are your plans for sound deadening on the floor now?
HogCanyonHopper
  • Turtle Points: 7333
  • Male Posts: 1,224
  • Member since Jul '10
« Reply #26 on: Jun 17, 2016, 06:53:07 AM »
:popcorn: looking goooood!!  :yesnod:
8T3
  • Turtle Points: -1
  • Member since Jun '07
« Reply #27 on: Jun 17, 2016, 11:21:14 PM »
This IS going to be an incredible build. I've had my hand in a few parts. Here's some pics.
This is the frame being sand blasted. Little Harbor Freight pressure blaster. We went through 10 bags of #30 sand. Recycled maybe 3/4 of it twice. That's my kid doing the blasting. Yes, he wore a respirator the whole time. Took a full day. But it was perfect when he was done.
3 coats of Rust-Oleum. The quart at Home Depot. Semi gloss. Thinned and sprayed. Seals everything up good, but will take a while to dry.
« Last Edit: Jun 17, 2016, 11:54:34 PM by 8T3 »
8T3
  • Turtle Points: -1
« Reply #28 on: Jun 17, 2016, 11:47:44 PM »
The bed has been blasted. It's in great shape. Almost zero rust. Had a camper shell on it the whole time. 3/4" carpeted particle board protected the bed floor and wheel tubs.
Joe made a perfect stand for the bed. Solid, square, and mobile.
At this point we're just surveying what needs to be done. The factory tow down hooks have been removed.  Both back bed corners need to be replaced. Remove all factory body sealer.  After that, it's just bodywork.
« Last Edit: Jun 17, 2016, 11:58:52 PM by 8T3 »
joe510 [OP]
« Reply #29 on: Jun 19, 2016, 12:00:36 AM »
I have to give a lot of credit where credit is due.  Greg (8T3) has been a huge help in almost every step of the way.  he has scrounged parts and tools for me and helped with body work and prep without asking for anything in return...  He is a great friend and true mentor when it comes to my project!
Thank you so far for all the help dude!!   :biggthumpup: :beer:
Last post May 29, 2006, 09:36:47 AM
by blackdiamond
Last post Aug 29, 2006, 08:20:27 PM
by Tice
Last post Aug 22, 2009, 02:38:22 AM
by Tallchevy
Last post Nov 02, 2011, 11:28:47 AM
by Rydell
Last post Mar 27, 2018, 08:26:31 AM
by fasterspider
