Author Topic: Spring in clutch pedal assy - does this look right?  (Read 3415 times)
swilson
  • Male Posts: 329
  • Member since Aug '11
    • My 1966 FJ40 Build Up
« on: May 21, 2016, 05:00:56 PM »
I'm swapping a 5spd into my factory auto 4Runner.  When I bought my used 5spd pedal assembly, the spring for the clutch pedal had been removed.  I put it in how I think it fits, but it makes the pedal behave weird.  Makes the pedal want to stay forward when the pedal is forward... but makes the pedal want to stay back when the pedal is depressed.
This might be normal since when everything is installed, the pressure plate would be pressing back when the pedal is depressed, I just don't know.
If you can compare my photos to your working assembly I'd be much obliged.  :usa:
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
OVRAROK
  • Turtle Points: 26840
  • Male Posts: 3,508
  • Member since Dec '10
this is a functioning unit, I springs forward, and springs backward, hard to keep in middle, if that makes sense
Sent from my HTC One_M8 using Tapatalk
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
do you have an FSM for your year of truck?
that will have exploded views of it
swilson [OP]
  • Male Posts: 329
Ovrarok, that also describes it... Won't stay in the middle.  Sounds like I've put it in correctly.  Thanks!
1964 FJ40 TBD
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Looks correct to me. All of mine that I've removed the master cylinder from will stick to the floor until the new one is installed and bled down.
01 double cab hunting truck
06 tacoma street truck
camhays556
  • Turtle Points: 498
  • Member since Nov '12
I pulled that spring out and used a spring similar to that of  first gen 4runner clutch pedal. The bushings wear out way to fast on those. heres a how to https://www.tacomaworld.com/threads/clutch-squeak-linear-spring-swap-tw-how-to.159429/
84Flatbed
  • Turtle Points: -196
  • Member since Jun '13
I did the same thing years ago on my tacoma. The plastic bushing wears out fast then you get an annoying squeak.  I do remember that spring having some tension to it when installed. I placed a rag over it to help keep it from flying when removing it.
Last post Mar 11, 2003, 06:27:11 AM
by vikingsven
Last post Jan 20, 2006, 08:17:55 AM
by trax28to
Last post Jan 14, 2007, 05:47:19 PM
by Yota1
Last post Sep 12, 2008, 09:12:40 AM
by 83MT
Last post Oct 13, 2012, 10:44:27 AM
by Cheesemaker
