What' that vibrating sound just before you start up the hill?
Around the 1:20 min mark? The sort of low frequency clicking noise? If so, that is the clutch pedal pivot. It has done that since day one. I've checked to grease it and it's already well lubricated...
9:35 is one example.
Gotcha. That is my ARB compressor cycling. (Until I fit a larger on-board air tank, it's one of two reasons why I'm not a fan of ARBs.)I'm running the High Output ARB Compressor (their medium sized offering) that despite having a cup-sized reservoir will cycle on every second time you engage a locker. Therefore, when I engage both lockers back-to-back or simultaneously, the comp will cycle.
Hi mike! What’s a guy pay for a 3.4l /a340f auto version of this with two 2.28 crawlboxes and adapter/spines shafts/ couplers to built it with the chain drive drivers drop original as the caboose? Thanks buddyPaul
I have the V1FA trandfer cases. I just needed a parts kit with a set of 4.7 gears. Everyone tells me the stuff should be on the stores webpage, but no luck.
I thing you would be disappointed with 4.7's you'd need 3rd or 4th gear to spin the mud out, 2.28 then your stock case, if you need to crawl put them both in low and you will be stupid slow for overlanding
Started by Mike D Engine
Started by V-Man Project Research and Build-Ups
Started by Hilux_Max Project Research and Build-Ups
Started by BigMike « 1 2 3 4 5 » Trail Reports, Events, and Gatherings
Started by JEFFKISTHENAME Project Research and Build-Ups
