Author Topic: Please Help- extra wire relating to charging system - 1980 Pickup  (Read 3823 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
Can someone please assist  Have an extra wire relating to charging system - 1980 Pickup 4X4.  The wire is light gauge and insulated, not sure where is should go.  Please see photo below.  sometimes the truck over charges, not sure if related to this wire.  any information is greatly appreciated.
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Is that the voltage regulator?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
yes, the voltage regulator is the silver box on top of photo, igniter to the immediate left (on top of the coil).
Thanks!
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
I found a wiring diagram at autozone.com
It shows 6 wires coming out of the regulator.
How many wires are coming out of that regulator to the plug?
If it's 6, I wouldn't worry about the extra wire.      Probably a replacement regulator that's used for multiple applications and not needed for the truck.
What's the voltage on the wire while the truck is running?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
It's a 6 wire voltage regulator.  But, the loose wire is not coming directly from the voltage regulator, it's part of the Toyota wiring harness (see photo).
good suggestion check voltage while the engine is running.   Thanks!
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
I thought it was the loose connector on the regulator you were talking about.......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
does not read any voltage when running, no continuity to ground, no continuity or ohms to positive post.
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,725
  • Member since Jul '12
  • Seattle, WA
    • My build thread
Just wandered out to look at Steves 82'
Looks like that wire is a ground. Needs to go to the block. You can see that on Steves it goes to the back of the power steering pump bracket.
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
Thanks a lot!  You guys Rock!  That makes sense, that's why I could'nt find a place for it around the igniter, coil, or distributer.  Thanks again!   :thumbs:
Last post Apr 26, 2005, 05:47:36 AM
by toyman2
Last post Feb 02, 2006, 06:20:43 PM
by Vic stuff
Last post Oct 23, 2006, 05:47:50 PM
by yotadork83
Last post Aug 09, 2008, 03:19:29 PM
by 79coyotefrg
Last post Feb 19, 2010, 09:33:02 AM
by MC387
