If offset is measured from centerline of wheel, a 8" wide rim with -12mm offset would sit further away from truck than a 9" wide rim with -12mm offset because it has half an inch more rim on either side of the center line. Am i overthinking and missing something simple?
I am currently running 15x8 wheels with -12mm offset. I am in the process of moving up to a 17x9 wheel but cannot get a straight answer on what offset to get. I would like to maintain the current tire to frame clearance that I have. So the conclusion i have come to is that I would need a 17x9 wheel with at least -18mm offset to equal my 15x8 with -12mm offset. Am I even in the ballpark?
Started by Skinny_Pedal General 4WD Discussion
Started by 86turboyota General 4WD Discussion
Started by bigman General 4WD Discussion
Started by milla85 Tire and Wheel Tech
Started by donutman126 « 1 2 » General 4WD Discussion
