Author Topic: 1982 Toyota pickup 4x4 22r stock! idle problem  (Read 12285 times)
KILLERQUIST
  • Turtle Points: -3
  • Male Posts: 36
  • Member since Nov '10
  • May the Four winds blow you safely home
« on: Jan 22, 2016, 03:47:52 PM »
i have a stock 1982 toyota 4x4 pick up with a 22r 140,000 VERY CLEAN  and well taken care of looks clean newer aisin carb,everythings there! starts up fine runs for like 5min then has a few light hickups of the idle and dies , fires right back up again but eventually just dies anyone have any recommendations in which direction to start with ,ive already looked for any obvious vaccum leaks or anything out of place found one line not hooked up to a tee but didnt improve the problem!
Thank You  :turtle:
KILLERQUIST
3 x 1980 Toyota 4x4 hilux(rolled,sold,sold)
1982 Toyota 4x4 hilux 5speed 22r(current)
1984 Toyota 4Runner 5speed 22r(sold)
1986 Toyota 4x4 pickup five speed 22r(sold)
1989 Toyota pickup 2wd(MIA)
1989 Ford F350 4x4 Crewcab 12v Cummins(Camper)
1990 Toyota 4Runner 5speed 22re(sold)
1991 Toyota pickup auto 3.0(sold)
1993 Toyota pickup 5speed 22re(sold)
1993 Toyota 4Runner 5speed 3.0(sold)
1995 Toyota 4Runner 5speed 3.0(MIA)
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Re: 1982 Toyota pickup 4x4 22r stock! idle problem
« Reply #1 on: Jan 22, 2016, 03:54:11 PM »
Look in the bowl and see if your fuel is boiling, or if the bowl is low.???
01 double cab hunting truck
06 tacoma street truck
KILLERQUIST [OP]
  • Turtle Points: -3
  • Male Posts: 36
« Reply #2 on: Jan 22, 2016, 04:44:31 PM »
does appear low , when its not running and about half way when it is , can see tiny bubbles dont know about boiling?
redneckcustoms13
  • Male Posts: 2,513
« Reply #3 on: Jan 23, 2016, 07:51:46 AM »
When it dies is the bowl still half full?
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26866
  • Male Posts: 3,502
  • Member since Dec '10
« Reply #4 on: Jan 23, 2016, 08:28:57 AM »
check the accel. pump passage. The small hole in the nozzle, under the gasket, may be some gunk in there,clean it out
Toyotadon
  • Turtle Points: 388
  • Male Posts: 267
  • Member since Dec '08
« Reply #5 on: Jan 23, 2016, 01:07:31 PM »
I will be watching this, as mine sometimes die at idle.  It also started doing it at speed, but I figured out that's my GM ignition already going out.
KILLERQUIST [OP]
  • Turtle Points: -3
  • Male Posts: 36
« Reply #6 on: Jan 23, 2016, 04:00:28 PM »
just went and checked stays half full when it dies.
KILLERQUIST [OP]
  • Turtle Points: -3
  • Male Posts: 36
« Reply #7 on: Jan 24, 2016, 06:38:41 PM »
when i get a chance ill try giving it a cleaning
Cheng Lo
  • Turtle Points: 271
  • Member since Apr '12
« Reply #8 on: Jan 24, 2016, 08:58:01 PM »
Check your choke?  Might be stuck open
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #9 on: Jan 25, 2016, 07:15:42 AM »
I am by no means a carb guru but I want to be.  I recently went from 3RZ to carb 22r in my 4runner.  I love running carb and I am determined to figure the 22r aisan carb out.
To start with here is what I think based on my experiences:
Look at your fuel filter.  You have the nice, cheap one that's up there on the fender well.  It sounds like you have fuel so that's probably not it but I've had mine run and drive on a slightly crusty fuel filter but idle poorly like that.
I agree on making sure your choke is working.  Get your air box top cover off and start it up so you can see things.  The choke, on the passenger side should be spring loaded in the closed position when the truck is cold then slowly open and go limp as it warms up.
I would then get into a manual and set the idle mixture and idle speed screws so you can establish a baseline there.
After setting those screws according to specs if it's still doing it then make tiny adjustments, like 1/4 turn out at a time on the idle mixture screw and 1/8 turn on the idle speed and see if it will idle.  Give the throttle a blip with your had as you make the adjustments while it's running.
Once you get it going keep adjusting to find it's happy place. There is nothing wrong with a 1,200 rpm idle with the advance hooked up.
That reminds me...  Is your timing set properly? Can't tell in the pic but it looks like it might be a little retarded. Might try advancing like 2 degrees and see if that helps.
« Last Edit: Jan 25, 2016, 07:34:43 AM by H8PVMNT »
– Steve McQueen
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
Toyotadon
  • Male Posts: 267
I think I remember seeing that awhile ago.  Now, you've given me something else to do while my truck is "under the knife".
KILLERQUIST [OP]
  • Turtle Points: -3
  • Male Posts: 36
Been messing with it latley and noticed the fuel filter on the fender wall is very low I'm surprised that it had been running better after driving it how from the shop what could be preventing the filter from filling up and what does the bubble and half full float point in the direction of? Thanks again!
redneckcustoms13
  • Male Posts: 2,513
Remove your vapor line and return line. Make sure both are clean ans clear.
KILLERQUIST [OP]
  • Turtle Points: -3
  • Male Posts: 36
Been some time so I'll fill y'all in eventually checked everything fuel related and found that a piece off the top of the carb was missing keepin the flap from closing , tied some metal around it and presto it was idling high at 2rpm but idling ended up needing to get it rebuilt ! Since then it's been running alot better but still won't do the classic first turn. I'm in process of replacing my catalytic converter on back. there's just something not right and thats when I noticed when I've been coming up to lights or stop signs it has a rough idle and my Oil pressure on my guage starts to drop :( bummer well peyotas worth fixing or upgrading no matter what so I'll keep you updated on all the fun
On a side note i found a nice  60/40 Tacoma bench seat in pristine condition with cover for 40$ of Craigslist from a kid who swaped STI seats into his 97, my swap came out great  so nice and simple to be able to utilize the space behind my seats! those stock buckets
Really had to goSafe travels
Last post Nov 07, 2007, 10:40:21 PM
by fatt_matt
Last post Jul 11, 2008, 06:30:05 PM
by 15.50_STock
Last post May 14, 2010, 01:10:02 PM
by 854RUN
Last post Oct 22, 2012, 03:54:14 PM
by ChrisA
Last post Jun 03, 2020, 07:46:20 PM
by RN48
