Author Topic: EFI Problems, help  (Read 1271 times)
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
EFI Problems, help
« on: Oct 13, 2006, 12:49:26 PM »
I have a wired set up, it is a 84 ext. cab on a 85 four runner frame and running gear, with a 87 efi motor swap. Now my problem is, when i drive it starts to bog down and sputter and pop and hesitate when you give it full throttle but if you baby it, it doesn't do quite as bad. I thought it was the alternator (the battery isn't holding a charge) put it in and it didn't work battery still loses charge so i had it tested 4 differant times all say its good, changed coil, new battery, computer, people have told me that it is fuel but it isn't consitant. could it be distributer, timing, or fuel?
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: EFI Problems, help
« Reply #1 on: Oct 13, 2006, 01:01:14 PM »
Have you adjusted your TPS Sensor, Valves, Timing, Cleaned Fuel Injectors, changed your Spark Plug Wires, Spark Plugs?
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #2 on: Oct 13, 2006, 01:18:49 PM »
Maybe a Fuel Pump?
yota_krawler [OP]
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #3 on: Oct 13, 2006, 01:43:33 PM »
when you take the fuel pump out crank it over how much should come out? it was a steady but not a very thrustful stream i have heard like 50 psi and it wasn't 50 psi
yota_krawler [OP]
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #4 on: Oct 13, 2006, 01:45:22 PM »
are carbed plug wires the same as efi or are they differant?
toynorcal
  • Turtle Points: 96
  • Male Posts: 435
  • Member since Jul '05
  • "Easyline"
« Reply #5 on: Oct 13, 2006, 02:14:47 PM »
I would start at your battery if its losing charge, but still tests good. Sounds like you have a bad ground connection or a draw on the system. You may want to go through the ingition and charging systems with a fine tooth comb.
Sputtering during acceleration is usually caused by poor air/fuel mixtures or bad spark. I would guess that you have a battery charging problem that is causing poor spark.
Last post Feb 01, 2004, 11:15:24 PM
by 84runner
Last post May 18, 2004, 10:11:11 PM
by WHITE_TRASH
Last post Oct 24, 2004, 10:08:28 AM
by robinhood4x4
Last post Nov 23, 2004, 07:10:31 AM
by bluetoy84
Last post Dec 15, 2004, 10:19:01 PM
by BLACKDOG
